Lunati Valve Spring Question
Old 05-30-2012, 03:16 PM
MR1911's Avatar
Default Lunati Valve Spring Question
Hey guys are the Lunati LS Dual Valve Spring kit ok to use as a stock replacement ? For the time being I am using a stock LS6 cam and dont know if its too much spring for it Seems most are happy with them with a cam but I see no feed back on a stock cam .
These are the ones I am talking about http://www.coloradospeed.com/index.p...ducts_id=13960
Old 05-30-2012, 03:36 PM
slammedc5's Avatar
Hum, might be to much spring for a stock cam. I'm no expert on this. But I run the lunati 660 dual spring, I have a pretty big cam though. 234/245 duration 630 lift 113lsa
Old 05-30-2012, 04:40 PM
Darkman's Avatar
Those springs will work, but will require hardened push rods as opposed to stock. They do represent overkill and you will likely make a little less power than with a good set of beehive valve springs.
Old 05-30-2012, 06:24 PM
MR1911's Avatar
I do have a set of trick flow push rods so i'm good there , and a little less power is no big deal as it has a maggie on it . I will do a cam maybe next year so this is just for now .
Old 05-30-2012, 10:14 PM
01ssreda4's Avatar
Agreed with Darkman, will work but not ideal by a long shot.
Old 05-31-2012, 08:51 AM
TurboBuick6's Avatar
Why not get a set of beehives for now? You can use all stock hardware, just rplace the springs and call it good till you get a cam? Even with a blower on there the beehives will be more than enough.
Old 05-31-2012, 09:36 AM
MR1911's Avatar
I dont want to replace springs twice The heads are off so I wanted to freshin things up while its apart and kill 2 birds with one stone all at once. And I dont want to do a cam at this time .
I know its not optimal guys just looking for feedback from people using it on a stock cam .
Old 05-31-2012, 07:30 PM
kenp's Avatar
That's a good choice. Will work just fine now and if you go with a more demanding cam.
