oil pumps
Old 03-30-2004, 10:35 AM
99 red Z's Avatar
Default oil pumps
Reading the issues with oil pumps, now I’m paranoid. Anyone know what fails on the oil pumps? What would be an adequate replacement? Where would be a good place to get one, and what’s the going cost? I'm having the heads P/P, getting mild cam, changing to LS6 PCV. Might as well replace the pump while I’m in there. thanks
Old 03-30-2004, 11:13 AM
01_SuperSlow's Avatar
Either a stock LS6 replacement or a ported one from one of the sponsors is a good way to go.
Old 03-30-2004, 11:19 AM
DenzSS's Avatar
Yup, stock LS6 or a blueprinted stocker by a sponsor. Especially since you have a 99.
Old 03-30-2004, 11:43 AM
99 red Z's Avatar
is it necesarry to have blue printed?
as of now, i can get new LS6 oil pump from dealer at $65(know parts guy)
TSP has ported ls6 oil pump for $130
GEN III performance has stock oil pump for $110(does't state LS1/6)
or Gen III Blueprinted Oil Pump for $180(again doesn't state 1/6)
TR Modified LS6 Oil Pump for $150
anythoughts?
Old 03-30-2004, 11:44 AM
DenzSS's Avatar
The stock LS6 pump is perfectly fine. Blueprinting is nice, but not required. It is a piece of mind thing mainly.
Old 03-30-2004, 12:05 PM
eallanboggs's Avatar
Have you ever disassembled one of these pumps? There isn't a whole lot to them. They are very basic in design in that they only have a DRIVE and DRIVEN gear. There is on overpressure relief, but if it opens that's NOT a failure. That's the way it's supposed to work. If the overpressure spring is too weak that's another story. If the piston gets stuck in the open position due to a burr in its' bore that's also a problem, but by the time that happens you have already reached on overpressure condition which should not happen on a properly serviced engine. The oil pump is self-lubricating because in doing its job of pumping oil it lubricates itself at the same time. I don't know how long it would take to wear one of these things out due to normal wear and tear, but I'd be willing to bet it would be in the hundreds of thousands of miles assuming the oil is changed at regular intervals. Even the oil filter mounting boss has an additional over pressure bypass in the event the filter becomes clogged due to lack of maintenance. The stock pump puts out approx 40 lbs, which is a lot more than needed at idle, because the pump rides on the crankshaft rather than on the cam which only spins at half speed.
Old 03-30-2004, 12:09 PM
Uthinkso's Avatar
Give us a call we have ported LS6 pumps on the shelf and can ship out today!
Old 03-30-2004, 02:17 PM
1QUIKWS6's Avatar
Yeah, I just had my P/P LS6 pump coated by AP - oil shedding on the outside/teflon on the inside (I just had to go that leetle xtra mile!)
Just awaiting it's arrival!
-Jay-
Old 04-10-2004, 01:27 PM
BillyRay's Avatar
I am in the middle of doing my second oil pump swap in about 6 months...
I have not idea why 2 oil pumps have gone out in that amount of time. The first was the stock pump, so I replaced it with a ported LS6 pump and it's gone bad as well...
Like has been said there really isn't much that can go wrong with them???
Anybody have any ideas????
Jesse
Old 04-10-2004, 01:43 PM
8POTS's Avatar
What is a good option for a 428 CID with Darton wet sleeves in an LS1 Block?
Is a modified LS6 pump a good Idea or something else?
Old 04-10-2004, 03:17 PM
SSEUL8R's Avatar
Im in the middle of a cam swap, and I replaced my stocker 98 pump with a stock LS6 pump. I got it for like $68 which is not bad when you consider it can save you a $$costly$$ rebuild.
Old 04-10-2004, 07:09 PM
stealth's Avatar
Get ARE's modified pump.
