SLP oil pump- What spring to run
Old 05-31-2012, 12:58 PM
Cwarta's Avatar
Default SLP oil pump- What spring to run
I just got my SLP ported oil pump in, and it came with 2 springs. One is for stock pressure, the other raises the stock pressure by 5 psi OFF idle. WOuld i potentialy get a little better oiling up in the valve train if i run the higher psi spring? Or will it just bypass it all? Thanks in advance.
P.S, thanks Maryland speed for the great parts and fast shipping!!!
Old 05-31-2012, 01:11 PM
badazz81z28's Avatar
I choose the stock spring. No need for higher pressure IMHO,
Old 05-31-2012, 01:14 PM
Cwarta's Avatar
Why is that? WOuld it not benifit from it, or does it just bypass more?
Old 05-31-2012, 01:39 PM
Because it increases pressure, not volume. Theres no reason to have an engine with 60 PSI oil pressure went 55 PSI is adequate. Thats just IMO
Old 05-31-2012, 09:59 PM
Evans752's Avatar
I left the stock one in mine too but real good question.
Old 06-01-2012, 09:33 AM
Cwarta's Avatar
Well e eryone keeps telling me to leave the stock one in. SO i guess thats what we will do...
Old 06-01-2012, 09:34 AM
Cwarta's Avatar
I guess it makes sence since all my bearing tollerances are still stock...
Old 06-01-2012, 10:03 AM
thunderstruck507's Avatar
I run a Lingenfelter ported pump and left the higher output spring in it when I installed it.
I checked with a calibrated gauge and with 0w-30 Syntec I had warm idle of 70psi and under rpm just shy of 90psi.
Quick Reply: SLP oil pump- What spring to run
