Pilot bearing wont go in!
Old 06-04-2012, 02:27 PM
703 CAMAROSS's Avatar
Default Pilot bearing wont go in!
I'm hammering it in with a socket and it will not go in! It's starting to get marks in the metal from the socket. Is this normal?
Old 06-04-2012, 03:22 PM
Grimes's Avatar
it should go in pretty easy. try putting it in the freezer for a little bit and also lubing the pilot hole
Old 06-04-2012, 03:24 PM
It said install it dry, its a compstar crank, should I need a different pilot bearing from stock?
Old 06-04-2012, 03:29 PM
gMAG's Avatar
The first thing I would do is to verify this by calling the factory or customer support.
Old 06-04-2012, 03:38 PM
gMAG's Avatar
Just wanted to add...I tapped mine in with a block of wood, which covered the entire surface area of the bearing. It went in easily.
Previously, I tried a PVC fitting instead of a socket. Tapping it in with this method caused the bearing to deflect, keeping it from being driven directly to the crankshaft.
Old 06-04-2012, 05:15 PM
I got it in. Just took more hitting!
Quick Reply: Pilot bearing wont go in!
