who is running a big hydrolic cam?
Old 03-31-2004, 03:37 AM
DOC OTIS's Avatar
Default who is running a big hydrolic cam?
anything bigger than a 244/244 .612/.612 on a 112lsa. I am building a 427 and the budget can't handle a solid roller conversion right now. I know the S1 cam is proven to make good power, but seems kinda wimpy for a big cube motor. Any one running a hydrolic cam in 25x/.6xx range or bigger? Dyno #'s and track times please if ya got them please. Just wondering how big you could go with a max effort hydrolic set-up, and no this isn't a daily driver, lol
Old 03-31-2004, 03:42 AM
kumar75150's Avatar
Mine isnt that big.
244 250 .634 .625 112lsa but I only have a Lunati stroker and not a big bore.
I am getting gears next week and MIGHT switch to something a little bigger.
Old 03-31-2004, 03:46 AM
DOC OTIS's Avatar
Originally Posted by kumar75150
Mine isnt that big.
any #'s on your set-up?
Old 03-31-2004, 06:14 AM
kumar75150's Avatar
I should have some updated numbers in about 2 weeks.
I made 484 and 452 last year with stock LS6 intake and TB.
Old 03-31-2004, 08:20 AM
stealth's Avatar
248/256, 602/609, 114/110
Old 03-31-2004, 09:33 AM
Colonel's Avatar
"I know the S1 cam is proven to make good power, but seems kinda wimpy for a big cube motor."
What's funny is that at the time people thought the R1 was a big cam! Folks thought I was nuts when we went to the S1.
Old 03-31-2004, 01:25 PM
DOC OTIS's Avatar
Ya, now guys are running cams almost that big in 346 ci motors The big cammed 346 cars seem to be running really good. Makes me wanna sell this S1 and put a real stick in this motor
Old 03-31-2004, 01:41 PM
SStroked 410's Avatar
wish I had dyno number or track times for you but I was trying to deal with comp cams about ordering this custom cam 250/256 .620/.626 112 LSA but had no luck for alittle over 1 month
I finally got a hold of someone that knows there stuff. So I will have a cam close to that soon. I only have 410ci and if I had a 427 I would try to go even bigger. I know theres proven cams out there but I want to try something different and try to step it up to the next level like these guys are doing with those lil 346's
Old 03-31-2004, 01:46 PM
DOC OTIS's Avatar
thats what i'm talking about. good luck with your set-up. by the way who are you dealing with about the cam?
Old 03-31-2004, 01:47 PM
DenzSS's Avatar
250/256 .620/.626
Hell, thats bigger than my solid. My lift is a higher, but otherwise you have me beat on duration with a hydraulic.
Old 03-31-2004, 01:51 PM
LOnSLO's Avatar
Tell Comp you want that cam on one of their "race hydraulic" profiles. Then tell them to put it on LS1 journals. That's what I did.
Old 03-31-2004, 01:56 PM
DOC OTIS's Avatar
any details on your set-up? Your sig says solid roller?
Old 03-31-2004, 01:58 PM
LOnSLO's Avatar
Yep, it's a solid roller. I picked a lobe pattern out of their master catalog, which was a big block race lobe. I just had them grind it for an LS1.
Old 03-31-2004, 02:09 PM
DenzSS's Avatar
Doc--your PM box is full, clean out some space so I can respond
DOC OTIS's Avatar
how long did it take them to get it to ya?
Old 03-31-2004, 02:20 PM
I was having a hard time dealing with comp cams untill I found the right person to talk to so now its either comp cams or cam motion. Theres a post I just put up in internal about it
good luck, your car should make some nice power with all those parts!
Post a dyno graph when you dyno the car.
Old 03-31-2004, 08:06 PM
stealth's Avatar
I see some guys here are "over cammin."
Old 03-31-2004, 08:14 PM
Thats what I used to think untill I started seeing more insane hp and tq
with some of these big *** cams in these 346's and strokers.
Look at thunders new cam, its crazy! A few years ago I remember anything over 230 was too big and a waste. Look at some of the cams today...big difference
Old 03-31-2004, 08:42 PM
GueSS Who's Avatar
<-----------244/252 620/635 112 here in a 408 with 9.7:1 compression
6.26 in the 1/8
Old 03-31-2004, 09:03 PM
6.26 in the 1/8
very nice,
10 seconds in the 1/4
this car have a blower?
any dyno numbers?
