will not crank over???
i have a 2001 z28 prc head torquer 3 etc, it had not been cranked for six months since my midtour leave on my deployment. it started twice and was knocking real bad and now wont start at all afetr i shut it off. before it had no issues now just cant find whats going on with it?
Hopefully was a safe tour, welcome back and thank you for your service!
Pull the dipstick and check oil level, wipe it on a white cloth and check for shiny metal. Report back w/ findings.
Pull the valve covers,the knocking sound might be a broken rocker or a spring.If spring/rocker is broke that would explain the no start...Probably no compression on that cylinder.
so i took the valve covers today and checked my rockers and springs and everything looked good just very dry, but as i took one of the valve covers off my back passenger side wire was not connected just barely on the wire and had acid so i dont know what kinda issues this could cause, i checked my oil and no metal chavings in it
