Bearing Clearance on Dragonslayer
Building my first iron block 390 with forged crank and rods from AES Racing. I already purchased these bearings listed below. However, after doing more research I am not to sure if these will work. Looks like the crank needs chamfered bearing?? Anybody have an idea and could recommend which bearings I should go with. Thanks
http://www.summitracing.com/parts/SUM-172300CL/
http://www.summitracing.com/parts/SUM-171000CL/
Ok, just purchased a new set: King Bearings KGB-MB5013XP Main Bearings, XP-Series and Summit SUM-171000H Rod Bearings. After spending a little time on Summit I think I have the correct stuff coming.
