Can I buy just one replacement head stud?
Old 06-15-2012, 08:07 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Default Can I buy just one replacement head stud?
When I was pulling my head studs out of my old block, one of the small 8mm studs ended up getting stuck in the block, and the allen head stripped. I finally said f'it and pulled it out with a pair of pliars and f'd up the threads.
So I need to get a replacement stud, but don't know if anyone sells them individually. Is this something I need to call ARP directly to get?
Thanks.
Old 06-15-2012, 08:29 PM
conan's Avatar
Call ARP they'll send you just one. I had a socket crack on me removing a head bolt (one of the big ones) stripped the head and they sent me just one.
Old 06-15-2012, 09:02 PM
gjohnsonws6's Avatar
Save yourself some trouble next time and use two nuts jammed together instead of pliers.
Old 06-15-2012, 09:33 PM
UNDER PRESSURE MOD
Good idea, thanks for the suggestion.
