Callies 3.8 inch LS1 crank?
Old 06-17-2012, 11:27 PM
BlackNiteWS6's Avatar
Default Callies 3.8 inch LS1 crank?
Has anyone heard about the 3.8" Callies crank for the LS1? I love the 387cid big bore engine. I drove in my buddies 382 cid all bore setup. I car so very quick. For those who say the big bore motor isn't all that great hasn't been in one long enough or whatever. I loved the way this car felt. The motor had power everywhere. And now Callies came up with the 3.8 cube crank. That's 406cid, now just add a D1SC with a front mount intercooler
Old 06-17-2012, 11:36 PM
LS6427's Avatar
Do you know if that 3.8" crank is made in China and finished in the USA?
Old 06-18-2012, 07:59 AM
simplysix's Avatar
Sorry to sidetrack the thread but I'm cunfused, doesn't a 4" crank make a 383? If so, how does the 3.8 crank get you to 406ci?
I'm missing something
Old 06-18-2012, 08:58 AM
Mike94ZLT1's Avatar
Bore size.
Old 06-18-2012, 03:15 PM
With a bore of 4.125" and a 3.8" stroke makes
406cid.
Old 06-18-2012, 03:21 PM
Default 3.8" crank
That's a good question, I'm not sure where it's made. I only read it somewhere that Callies/Compstar makes a 3.800" and a 3.825" LS1 crank, but i can't find it. Not even on Callies web site. I love the idea of the 4.125" bore, and with a 3.8" stroke sounds like a good bore to stroke ratio. So you get your cake and eat it too...you get more bore and stroke
Just did the math, the 3.825 crank with 4.125" bore make a 409 cube motor.
Old 06-18-2012, 03:43 PM
LS6427's Avatar
I'm doing an iron 6.0L at 4.030 with a 4" crank = 408ci....then I'm gonna ram it with a 94mm turbo. So 1100-1200 RWHP will happen.........
I was told by a builder the Compstar is made in China and finished here in the USA. The Dragonslayer is made and finished here in the USA.
I was just quoted today for the Compstar crank and rods, Diamond pistons, rings and pins......completely balanced ready for install....$2700
Dragonslayer crank and Ultra I beam rods, Diamond pistons, completely balanced = $3840
Think I definitely need the Dragonslayer.........I was told its made here and uses more pure steel..........but I don't know.......
I'll start a thread asking...........I have to make a decision this week.
Old 06-18-2012, 06:27 PM
^^^sounds like a nice setup you're going with, congrats. I just got an email about 3 hours ago from Beau Novak at Scoggin/Dickey. The said they sell the 3.85" Callies crank. Here's a cut and paste of their email to me:
Callies makes a 3.825" stroke crank we keep in stock for $549.95. No
3.800" that I am aware of.
Beau Novak
Scoggin Dickey Parts Center
(800) 456-0211 ext. 355
www.sdparts.com
Pretty good price if it's made here in the USA.
I just replied to their email asking them if the crank is made in the US. See what they say.
Den
Old 06-18-2012, 06:48 PM
LS6427's Avatar
Beau Novak
www.sdparts.com
Den
Another $200 for balancing and thats a great price......I would only have a 390ci. though......really wanted the 408ci to get that 94mm spinning.
I wonder if its good for 1200 HP.
Old 06-19-2012, 05:45 PM
Oh check this out...Beau Novak from Scoggin/Dickey wrote to me about 9 hours ago. The 3.825" crank is made in China and machined in the USA That friggin sucks big time.
Old 06-19-2012, 11:19 PM
AES Racing's Avatar
That is a Compstar crankshaft NOT a callies dragonslayer
Callies built the 3.800" dragonslayer crankshaft exclusively for AES when we put in a volume order.
Callies forgings (not compstar) come from Japan and are finished machined and hardend in US at Callies.
Fraser
Old 06-20-2012, 12:37 AM
Thanks for replying. So is the 3.8" crank still available?
I like the idea of adding more stroke to the 4.125 bore for a total
of 406 cubes. That's respectful.
Old 12-28-2016, 06:21 PM
SN95+5.3's Avatar
I know Im resurrecting a OLLD post but I have a Callies Magnum thats 3.825 and a 6.125 rod..what compression height piston would I need?
Old 12-28-2016, 06:41 PM
KCS
Moderator
KCS's Avatar
Compression Height = Block Deck Height - (Rod Length + 1/2 stroke)
Old 12-28-2016, 06:47 PM
91 Z28's Avatar
Based on your crank and rods you'll need a 1.2025" Compression height Check this out http://www.lunatipower.com/Tech/Pist...ionHeight.aspx
Old 12-28-2016, 07:11 PM
SN95+5.3's Avatar
Thanks guys! The piston I ordered has a 1.205 CH so with the .51 gasket and oring I should be safe.
Old 12-29-2016, 08:24 AM
pantera_efi's Avatar
Default Bob Weight = 1850
Hi, I too sell the China Crankshaft with VERY good luck in BAJA 1000 races. (NO Failures)
The SAME forging as Callies, my guess is the same Bob Weight of 1850.
When this is matched to our rods, pistons, pins, it could require a Bob Weight of 1835, if so NO Balance required, just MATCH rod and piston weights.
Lance
Quick Reply: Callies 3.8 inch LS1 crank?
