Oil leaking into maf????
Old 06-19-2012, 09:36 AM
svt_jesse's Avatar
Default Oil leaking into maf????
I have a issue with my ta its a 02 ls1 randomly started leaking oil from the intake into the elbow where the intake and maf connect. What could be causing this? I changed out the pvc already and no fix.. The car was turned on every once in a while for the last 2 years doesnt get used much if this helps any...
Old 06-19-2012, 09:43 AM
Moderator
jimmyblue's Avatar
The "makeup air" side of the PCV is unchecked and flows
in reverse at WOT where you have crankcase positive
pressure and inlet trace negative pressure. A catch in
that line could help you out.
Old 06-19-2012, 01:53 PM
LS1-450's Avatar
^ This.
I just use a cheap in-line fuel filter.
Old 06-19-2012, 08:49 PM
svt_jesse's Avatar
Im sry guys I dont mean to sounds like an idiot but im lost.. A catch in the line? the pcv thing was changed out but didnt fix the problem
Old 06-20-2012, 07:34 AM
LS1-450's Avatar
"catch" means oil catch can. Do a search for catch cans or PCV line. Results from the search will explain everything needed.
Old 06-20-2012, 07:33 PM
svt_jesse's Avatar
Thanks a lot! Do I really need to do all that? or is there a cheaper way around this never did it before but now that the car sat for 2 years 4 months later of driving it it started to.
Quick Reply: Oil leaking into maf????
