Jy 5.3, is it junk?
Old 06-19-2012, 03:18 PM
360demonRT's Avatar
Default Jy 5.3, is it junk?
I finally got moved into my new place and just pulled the cam out of my junkyard 5.3 to swap in a turbo cam. Below are the pictures.
The lobe is the third from the front (lifter turns free but looks bad) the shavings are on the back of the cam. Dont know if it matters but with timing chain off and retainer plate onthe cam has just over a 1/4 inch of front back play... there are shavings in other spota on the cam as well and some in the pan. Is this motor basically trash unless i have new bearings put in? Thanks
Old 06-19-2012, 04:36 PM
360demonRT's Avatar
Is there a good chance that metal has junked some bearings or throw it togethet with a new cam and lifters and see what happens or?
Old 06-19-2012, 05:07 PM
parks450's Avatar
I wouldn't say trash but I say it need a cleaning to get all the debris out. I would recommend at least new cam bearings. You could Doyle check the crank and rod bearings to make sure they are ok. If they are just make sure you keep them in the same locations
Old 06-19-2012, 05:59 PM
Gunslinger09's Avatar
Clean the block up real good, blow out the oil passages and check the bearings. If they are bad just do a cheap overhaul with the kit from GM. If they are good replace the cam and lifters and go to town with the turbo build. I assume you are going to build a forged piston motor for it in the near future anyway so why not get it going as is now and get your set up together for the motor swap later.
Old 06-19-2012, 08:42 PM
360demonRT's Avatar
Thanks for the advice guys. If i pull the mains can i reuse the stock bolts?
Old 06-19-2012, 08:49 PM
LS1MCSS's Avatar
Yes you can.
Old 06-19-2012, 09:10 PM
Originally Posted by LS1MCSS
Yes you can.
No the rod and main bolts are torq to yield just like the head bolts.
Old 06-19-2012, 09:37 PM
cartel's Avatar
im almost same place-- so ARP bolts needed?
Old 06-19-2012, 10:48 PM
AlterEgo's Avatar
arp would be the best route
Old 06-20-2012, 05:16 AM
360demonRT's Avatar
I thought using arp bolts required some sort of machine work? Tbought it was just stock and kartek (sp?) that you could just throw in in the garage. Am i wrong? Also found this after i wiped the oil off the front cam bearing... is there anyway this motor has only the advertised 50k on it?
finally figurex how to get the (img) on my mobile app lol
Old 06-20-2012, 05:38 AM
TXSZ66AVLANCHE's Avatar
The main and rod bolts are re-usable...look it up in service manual. This engine needs to be fully torn down and thoroughly cleaned, oil passages need to be meticulously cleaned. New rod, main, and cam bearing. It would be foolish to reuse the oil.
Great example of why a junk yard engine is.....a junk yard engine.
Old 06-20-2012, 06:58 AM
mark21742's Avatar
If you don't take care of an engine and run it low on oil, and font change the oil it can look worse than yours in a lot fewer miles
Old 06-20-2012, 01:18 PM
360demonRT's Avatar
Sounds like i would be better off selling the good parts off this motor for yardsale prices and playing russian roullete with another jy motor. But just tare this one down and check it out before my 1month warranty runs out
Quick Reply: Jy 5.3, is it junk?
