Comp Cams 1.7 Shaft mount
Originally Posted by Tech
Has anyone else had fitment or quality control issues with them?
I also cut the baffles out of the valve covers and clearanced a few places that looked like they would hit. The cover was close but I never finished the install to see if it was going to require a spacer.
I had re-installed the heads on the motor and already had new pushrods for the cam. The car had been down (in the street) for 4 weeks waiting for B/O head bolts and I didn't feel like ripping everything apart again.
Quality wise looked great. I just wish I knew about the other issues before putting the heads on.
Originally Posted by SSmokin 01
Mine are sitting on the shelf in the garage right now collecting dust. I was under the impression they would bolt right in. Then after going for the install I found out you need to open up the pushrod holes in the head and also needed custom length pushrods.
If all of these things are true, Comp will be getting a nasty letter from me wasting my time.
What year car did you try to install them on?
Comp said they had issues with them fitting under 97-98 valve covers (perimeter bolt) but they *should* fit under mine.
I can deal with spacers but I can't deal with removing the head to have them milled.
7 Second Club
I had to run:
6.150 pushrods should used 6.100
The holes got slotted .150 - .200 depending on how the casting was drilled. Let me tell you I have actually installed them and don't know how many times or ways I can say THEY DON'T FIT UNDER THE STOCK VALVE COVERS. I ground the divider out, ground down the bolt bosses, cut the edges, basically gutted out the valve covers and they dont fit. Everyone promised me that they fit under the valve covers and once I found out that they didn't fit, the tech said that they made a *slight* measurement error. I guess I had a very bad experience and would never do business with this company or buy their product from another vendor.
Custom Comp Cam 232 / 238 XER 111 lsa
well you haven't talked to the right person at comp..they just recently changed vendors in which they get the shaft mounts from..ther are supposed to be a better fit..the swap over was just a few weeks ago
Senior Member
