Stock LS1 engine with a tick, PLEASE HELP!
This just started happening. It happens after about 15 seconds of starting the car. I didn't over-rev or anything. The noise is relatively quiet and it seems to be coming from the top end, driver side bank. Lifter or pushrod maybe? I made a video of it, you may need to turn the volume up to hear it. I can hear it even with the hood closed.
Wow! That's interesting, never would have guessed it was the oil. My car has been ran with Mobil 1 synthetic 5w30 its whole life. Maybe I'll switch to a different oil and see if anything changes. Will the sound disappear after the first oil change with a switch to different oil, or is it a gradual process?
In each of my DD's I've had, I've used lucas heavy duty oil stabilizer and it would sometimes clear up any weird noises. I'm assuming it would also clear up this sound. Should I use it, or is it something I shouldn't be pouring into my engine? What do you guys think about the product?
traveling mod
Early years of the ls engine did not have coated piston skirts so it is common to get piston slap until the piston heats up and expands.
GM later corrected this by putting a coating on the skirts to prevent the noise..
