SES light flashing
Old 06-23-2012, 03:56 PM
Six8888's Avatar
Default SES light flashing
My SES light flashes but only under heavy acceleration, if I floor it while on freeway for example the ses light flashes and it seems to run rough, when I slow down the light stops flashing and it runs normally. Any ideas what this could be? Thanks in advance
Old 06-23-2012, 04:11 PM
LS-ONE_DAY's Avatar
Done anything to the car recently? That means there are multiple random misfires in the cylinders. It's not good.
Old 06-23-2012, 04:25 PM
Six8888's Avatar
nothing recently
Old 06-23-2012, 04:26 PM
Six8888's Avatar
Only recent even was moving from So Cal to Houston Texas
Six8888's Avatar
Can an 02 sensor cause this?
Old 06-23-2012, 05:15 PM
Captain Double Post
BOBS99SS's Avatar
I have never heard of a 02 sensor causing a misfire, i had a flashing ses light in the beginning parts of tunning my car, its a big cam car, but when i took it back to my buddy i never had the problem since, but mine would occur doing around 30 mph, im sure someone can give ya some better ideas, did you have it scanned? What codes came up?
Old 06-23-2012, 07:07 PM
crazyelf's Avatar
O2 sensor has done this to me before.
Old 06-23-2012, 07:29 PM
Darkman's Avatar
A flashing SES indicates that the system is detecting emission levels/conditions that threaten to ruin the catalytic converter.
Old 06-24-2012, 07:15 AM
bristol16's Avatar
Get the code checked at a local parts store if you don't have your own scanner. Flashing light and running rough usually means a misfire P0300-P0308 has probably set the light, it can usually give you a heads up as to what cylinder to start checking for a problem. Not a good idea to make it keep flashing, could potentially damage the engine or the cats if you have them like Darkman said. Once you know what cylinder it is on you can start swapping parts until the misfire moves. If it's a P0300 (random misfire) it could be a fueling issue or any number of other problems. Get the code checked first so you know what you are dealing with.
Old 06-24-2012, 08:37 AM
Old Geezer's Avatar
Talking
AT WFO, the O2's are not "in the picture"......
Old 06-24-2012, 08:57 AM
wildcamaro's Avatar
Get it checked, prob a dead cylinder
Old 06-24-2012, 09:12 AM
LS1121's Avatar
fuel pump going?
Old 06-24-2012, 12:48 PM
Six8888's Avatar
if it was a dead cyl wouldn't it run rough all the time?
Old 06-24-2012, 01:39 PM
zracer323's Avatar
Bad spark plug, spark plug wire or coil pack can cause this as well.
Old 06-24-2012, 09:11 PM
massls1guy's Avatar
Exactly, this happened to me. I had a bad spark plug wire that only gave me the flashing SES under acceleration.
Old 06-24-2012, 09:16 PM
baalic's Avatar
Ok i just went through a ton of bug hunting myself, i had the ecact problem, with a few others. Changed my cat, parts of the proem fixed, still ses light, changed maf too. Car runs like a ******* champ now. I too thought missfires because that's what tech said. They were wrong. New MAF and CAT and voila!!
Try those.
Old 06-24-2012, 09:17 PM
LS-ONE_DAY's Avatar
Yeah...I had it happen after I installed my headers...forgot to plug the coil pack in and drove it like 60 miles on the highway afterward like a dumbass. Luckily I think everything ended up alright.
Old 06-24-2012, 09:18 PM
baalic's Avatar
On that note, flashing ses light at idle, is usually a misfire. I had that too once... But what your explaining sounds line what i just fixed. 500 bucks and 2 months of hunting later..
Old 06-24-2012, 09:19 PM
bristol16's Avatar
Buying a new maf and cat are quite a bit more expensive than getting the code pulled for free and swapping around a plug, wire, and coil if possible...all of which is free.
Find out what the problem is before you go pissing away money on parts. It's possible it is maf and/or cat but I would make sure before I started blindly throwing parts at it.
Old 06-24-2012, 09:29 PM
baalic's Avatar
My code for it flashing, never came up. I did have a lean bank 1 and bank 2.
After over a year and a half running it with flashing ses light at heavy acceleration like that, messing with plugs, coils, wires. Etc. Well, nothing helped. I downed my car for 2 months. First thing they did was change the cats, that fixed a lot of my problems as at high rpms, it would stall out a little and get hung up at 5100 rpms, not shifting and not accelerating. Cat fixed that, and that flashing ses light but my codes persisted. Tried cleaning MAF, didn't help, replaced MAF. No codes and no flashing ses. Fwiw, getting my cat replaced was 200, maf was 100.. Thats not a lot of money. And i paid someone to do the cat...
Quick Reply: SES light flashing
