Heads on a stock bottom end?
Old 06-23-2012, 06:07 PM
2000xSILVERxWS6's Avatar
Default Heads on a stock bottom end?
How much will a stock bottom end hold up against? Would there be any issues with raising compression on a stock ls1? Would a stock ls1 with +100,000 miles be able to handle stg 2.5or 3 heads (ls6 or 5.3) from tsp? I know it depends largely on the car in particular, but all opinions are appreciated, thanks guys.
Old 06-23-2012, 07:08 PM
crazyelf's Avatar
Its been done thousands of times. Just put H/C/I on my car at 125k miles
Old 06-23-2012, 10:34 PM
TransAmWS.6's Avatar
Absolutely not going to be a problem if the car has been/is being maintained properly. There are countless guys on here with raised compression on their high mileage stock shortblock LS1's putting down strong numbers and they hold up just fine.
Old 06-24-2012, 12:25 PM
PREDATOR-Z's Avatar
IMO do a compression and leak down tests. Based on the results you'll have a clearer idea of the health of your motor and how to proceed in modifying.
Old 06-24-2012, 12:45 PM
TransAmcoupe98's Avatar
You won't need stage 3 ported 243's. 2.5 at the most and you SHOULD be fine barring any problems already present you aren't aware of.
Old 08-28-2012, 07:59 PM
jbro90's Avatar
hey guys just found this thread and you should do what im going to have done to mine if you canafford it. i have no buget im just saving for everything i like but i have talked to texas speed countless times and hours and have decided on doing 227 heads ms4 cam fast 102/102 and then go 383 . should yeild great results just saying
Quick Reply: Heads on a stock bottom end?
