Cam Question!!!
Old 04-01-2004, 12:22 AM
hpponline.net's Avatar
Default Cam Question!!!
ok so here it is. i want to get an ls6 cam and put on my 00 camaro ss. i want it because it wont make the car sound much different and it will be a sleeper. i was wondering how much hp this would add?? and also wondering what else i would need to add to this so that it wont hurt my engine.
i need all the help i can get so let me know
thanks everyone!!
-nathan
Old 04-01-2004, 12:34 AM
onyxxtreme's Avatar
i dont think it'll add much, with stock ls1 heads
you need the ls6 springs with that cam, btw
Old 04-01-2004, 12:40 AM
BBADWS6's Avatar
you might as well get a little larger cam, the ls6 cam can show a 20 hp increase. If you have somewhat stock exhaust you can run a larger cam than the ls6 and get a almost stock idle. MTI has a "sleeper" cam available.
Old 04-01-2004, 04:44 PM
I Dont Have Stock Exhaust I Have Long Tubes And True Duals. No Muffler Or Anything On It. And I Might Be Getting Gmmg Chambered Exhaust. So Pretty Much If I Want It To Sound Stock Get And Ls6 Cam??
Old 04-01-2004, 05:50 PM
Chop-Foo Director
PendragonZ's Avatar
For sounding stock, you can go with the LS6. Since you have LT's,
you'll see a pretty good gain.
BUT, you can go with an "old man cam" or "stealth" cam, from places
like TR or MTI, and they are going to sound close to stock and give
you a much bigger gain.
Old 04-01-2004, 06:07 PM
Tranzor's Avatar
LS6 cam is a good way to go if you're looking for a decent gain, stock idle, while spending the least amount of money... it's a good cam if you're working on a limited budget.
With the LS6 cam, all you'll need to do is change to the matching '02+ LS6 springs... you can stay with stock pushrods, timing chain, oil pump, etc. and stock tuning.
Old 04-02-2004, 01:07 AM
onyxxtreme's Avatar
you'll still wanna raise the redline with the LS6 cam though
Old 04-02-2004, 06:07 AM
equandt's Avatar
The Lingenfelter GT2-3 is the king of the sleeper cams. You might want to look into that cam as well.
Old 04-02-2004, 10:30 AM
Tranzor's Avatar
Yep, you can easily shift the LS6 cam at around 6400 rpms or so...
Old 04-02-2004, 10:51 AM
2xLS1's Avatar
I hate when everyone says you will only gain 20 hp with that cam. Too many people only concentrate on peak numbers. You will have way more than a 20 hp gain at 6400 over the stock cam.
Old 04-03-2004, 08:02 AM
Dan
Dan's Avatar
I am installing the LS6 Cam Soon, is it a toss up on the pushrods..I have seen 50/50 saying keep the stock ones or use the Chrome Molly, Manly's 7.40.. any thoughts?
Old 04-04-2004, 01:39 AM
so i can raise the rev to 6400?? and it wont hurt the engine?? should i go ahead and get pushrods since i mean im gonna have everything off to put the cam in anyways right?? i mean it cant hurt it and at anything it would be beter for the engine.. any thoughts?? im not too good on what all the numbers on the cams and pushrods so what should i get that would work good with the ls6 cam??
Old 04-04-2004, 09:35 AM
Dan
Dan's Avatar
From what I hear the cam makes power over the LS1 from 3500 up to redline..I think you will be safe with 6400rpm.I asked someone who has a Z06 Vette, he said his car redlines at 6600, I need to get more input to see what redline is the best..If you have the extra money get the Pushrods that I mentioned above, It's extra insurance
http://www.sdpc2000.com/cart.asp?act...art&catid=1994
Old 04-04-2004, 09:45 AM
MSURacing's Avatar
I think you guys are forgetting about one thing, HOLLOW STEM VALVES!!!!! You have to remember that the ZO6 has hollow stem valves that allow it to go up to the higher rpm. If you use your standard LS1 valves with the Z06 springs, you should probably keep the rpm's at the 6400 RPM. That is the only way GM was able to go to that rpm with that cam.
Yes, the LS6 springs are better, but you have to remember that it is a package deal, springs, cam and valves.
You would probably be better off going with a sleeper cam from one of the mentioned companies because they use more duration and less lift. Hope this helps out.
Old 04-05-2004, 12:38 AM
so i would be safe redlining it at 6400 though right?? as long as i can get away with that redline without damaging the engine then thats fine. i dont think i would put it up to 6600. has anyone ever heard of anybody with and ls6 cam in an ls1 engine having any problems??
