At what HP does the flow on 241s become an issue?
I have an LQ4 I am building. Right now I have a set of 317 heads on it. I am wanting to up the compression without milling the heads I currently have. I have been looking seriously at a set of 243s or 799s. Lately I have been seeing a good many 241s for sale, and at a much better price. I was wondering, at what HP level do the 241s lower flow rates become a limiting factor? Would I see enough gains from the increased compression to offset the lower flow of the 241s compared to the 317s?
This setup is going in a 66 chevelle. My goal is around 425-450hp at the flywheel, or 350 or so at the wheels. I want the power mainly in the lower rpm range as it will be more of a cruiser/street car than a track car. I would like to get into that power range as cheap as I can, because honestly if I can get the power I want and save a few dollars I can put that money toward other parts of the build. I plan to hold on to the 317s, because if in the future I decide to go with more power it will most likely be through a forced induction setup of some kind.
I am new to the LS scene, so please forgive the seemingly basic questions.
There's a Gto making 455/397 to the wheels with AI 219cc 241 heads. The power you want should be easy, btw my dad has a 67 chevelle hes restoring right now. Post pics of your car lol
I am going to start hitting up a few ads on here and try to pick up a set of 241s then. The car is in the early stages of restoration. Here is a pic of it as of a week ago:
And here it is before I took it apart:
Oh I realize that. But, if I can get to my HP goal cheaper by going with the 241s vs the 243s I figured I may as well. If it weren't for the fact I am still running a 45yr old 10 bolt and my wife will be driving the car some I would get the 243s anyway knowing they would support more power than the 241s if I made changes down the road. That's the reason I am keeping the 317s, in case I go forced induction later on. I haven't bought any heads yet either so I may still end up with 243s.
350 at the wheels should be easily attainable with 241s and bolt ons. If you decide to go with more power later a good port job from our sponsors will get you damn close to whats available from a good aftermarket casting like AFR or Trick flow. Buy the cheap 241s in my opinion
Where I was going was the 317s have the same ports as the 243s. IMO the 317s should get you your goal without having to buy any additional heads.
Yes I understand the compression is lower. Your goal is quite modest though so I don't think you need to spend a few hundred dollars(not just 241s but gaskets and bolts) swapping heads to raise compression.
I understand the wife driving it thing, my wife has even raced my car, and on rare occasion taken it grocery shopping if I was working on her w-body 3.4l FWD turd.
I had kicked around the idea of shaving the 317s. I decided against it in case I decided to boost it later. It's still not completely out of the question though. I am checking on a set of 241s with springs right now. If that doesn't work out maybe milling the 317s may be my best option.
You can have the chambers in the 317s filled in and therefore reduce chamber size. if you get them to 64cc, you'll basically end up with 243 clones. Advanced Induction does such work.
If FI ill leave it alone and throw a frount mount turbo or procharger on it.
If NA Ill slap some ls3/l92 heads on it down the line and get a good sized cam and fast for it.
I'm pulling the heads as soon as I get the engine fitted in the car. I haven't looked at it internally so I plan to check the cylinders before I button the front cap back on the car. That's one of the reasons I considered swapping the heads out. The old ones will be off anyway, so I will be getting bolts and gaskets regardless.
