reuse or get new dowel pins for heads?
Old 07-04-2012, 08:16 AM
fst100's Avatar
Question reuse or get new dowel pins for heads?
got my 317 heads back from the machine shop. cleaned and a 3 angle valve job. is it okay to reuse the dowel pins or is it best to get new ones from the parts store? did a search on here and google but did not get an answer.
TIA
currently what the motor looks like right now(painted the block primer gray)
Old 07-04-2012, 08:23 AM
Darkman's Avatar
I reused mine - no issues.
Old 07-04-2012, 08:35 AM
fst100's Avatar
noob question but does the dowel pins get tapped or pressed into the heads or into the block? or doesnt really matter just so long they're being used?
TIA
Old 07-04-2012, 08:38 AM
Gunslinger09's Avatar
The dowels are pressed in.
Old 07-04-2012, 08:40 AM
fst100's Avatar
hrmmm....how to press the pin in? any special tools or best to take it back to the machine shop that i took to get it cleaned/worked on?
Old 07-04-2012, 08:45 AM
You can tap a new pin in with a mallet. I have heard of people getting the old ones out with a thread die.
Old 07-04-2012, 08:47 AM
fst100's Avatar
ok. might as well get new ones and use the mallet technique....thanks gunslinger09
Old 07-04-2012, 12:57 PM
wildcamaro's Avatar
Reuse
Old 07-05-2012, 04:57 PM
fst100's Avatar
checked the head bolt holes on both sides to clean out anything in there and noticed the bottom 3 were dry(thats good right?) using a paper towel rolled really thin to squeeze in there. the upper 3 however i noticed the paper towel picked up oil, about an inch deep. is that normal and i should keep at it using the paper towel to pick up all of the oil until its dry correct? the upper outer holes were dry FWIW.
Old 07-05-2012, 05:55 PM
Stop with the paper towels in the bolt holes. Pick up a set of engine cleaning brushes and use compressed air to blow them out. There is a thread about a guy losing half a paper towel in a bolt hole.
Old 07-05-2012, 06:06 PM
fst100's Avatar
good to know. however is the bottom 3 holes have coolant and the top 3 have oil?
Quick Reply: reuse or get new dowel pins for heads?
