Sorry but...spec my cam?...LQ9 408.
Old 07-04-2012, 11:35 PM
wcialrlter's Avatar
Default Sorry but...spec my cam?...LQ9 408.
I've been researching for weeks and still can't pull the trigger on a particular part number...
This is the first motor I've totally spec-ed on my own so I'm a bit apprehensive I guess.
LQ9 408
4" stroke
12:1
243 PP heads (already had them from a blown up 5.7...they're still good)
LS6 intake
42lb injectors
This is going in a 3800lb off-road race truck. Stall in a 4L80 is about 3k but I often run in a 2:1 low range so that throws in another factor...
I want a max torque engine. This style of racing is a constant barrage of mini drag races in the dirt. Constant 0-60mph runs.
I need a rock solid idle as well and it'll be idling around 1000rpms to keep the hydro steering pumps turning (full hydraulic steering...if the engine ain't running you ain't turning).
I know...not your average request...thoughts from anyone?
Old 07-05-2012, 02:33 AM
mark21742's Avatar
Id look at a mid 230s cam, maybe even an ms 3 or 4....they are bigger cams in a stock cube motor, but mid sized in a 408 to keep your lower torque up. I was running a 4,000 stall and daily driving my 408 with a 255/271 .624/.624 115 lsa cam
Old 07-05-2012, 03:02 AM
bww3588's Avatar
Honestly, in your case, I would call Geoff at EPS and give him the run down.
Old 07-05-2012, 06:53 AM
ss454327's Avatar
I would run something like a 239/242 LSL/LXL cam on a 112LSA 109ICL.
Old 07-05-2012, 10:01 AM
DallasFMS's Avatar
Let Allan @ Futral Motorsports spec a cam for your setup.
Follow the link below
Custom Cam Worksheet
Fill out as much information as you can.
Old 07-05-2012, 10:16 AM
wcialrlter's Avatar
That worksheet is all kinds of screwed up on any browser I view it in. I'll put some info where I think it's supposed to go. Thanks.
Old 07-05-2012, 10:36 AM
11 Second Truck Club
MPFD's Avatar
Will an MS3 still have a little lope in a 408? would it be comparable to a 228r in a 6 liter?
Old 07-05-2012, 11:08 AM
DallasFMS's Avatar
Yeah we need to get it updated. Surprisingly it looks best on Safari on the iPhone. Which is weird since it is supposed to optimized for Internet Explorer.
Old 07-05-2012, 11:19 AM
wcialrlter's Avatar
What more info do you need that's not in the thread here? Call Allan over and tell him to look at the screen.
Old 07-05-2012, 12:24 PM
DallasFMS's Avatar
No kidding. I will see what I can do for ya.
Quick Reply: Sorry but...spec my cam?...LQ9 408.
