What will my compression be??
Anyone can give me a idea of what the CR will be. 2001 LQ4.stock stroke, stock bore 4.00, LS9 HG, stock 862/ 5.3 heads Flat tops. If install the flat top LQ9 pistons what will CR be? Im thinking if I go with the dish LQ4 pistons it will be the stock 9.4. Thanks.
LS1Tech Premium Sponsor
With the LQ4 stock bottom end (dished pistons) and that top end, you'll net about 10.5:1 static compression ratio. With the LQ9 flat-top pistons in there, it'd be about 11.3:1 or so.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Wow, with stock dish pistons it will be10.5? Those 862 5.3 heads must have a small cc chamber! Matt tell me the rod&piston combo that will live at 14psi? Will the stock rods live? Im on a really tight budget, but I dont want to go back with stock rods&pistons unless they can take 14psi. I cant seem to get the pistons to match the rods when I look. I see (Texas-Speed) has some Scat rods for aprox $309, but cant find a dish piston with the right pin size, help me out here.
