6.0 cam in 5.3
Old 07-07-2012, 10:42 PM
07silveradoZ71's Avatar
Default 6.0 cam in 5.3
I have a gernaded 6.0 out of aa 03' SS silverado, would there be any advantage in swapping this cam into my 07' Z71 5.3 ?
Old 07-09-2012, 07:49 PM
2000TransAmWS6's Avatar
The cam from the 6.0 has more lift and duration than the cam from the 5.3, so there is power to be gained, but I would think that it wouldn't be much more than 10 hp.
If you're bored and want to give it a try I'd say go for it!
Old 07-09-2012, 08:43 PM
Bo185's Avatar
No not worth it. And 2007 was a crry over year so it could be a Gen III or Gen IV motor. And if its a Gen IV motor it will not work since it need a single bolt style for the cam gear and trigger wheel.
Here's the LQ9 12561721 cam specs
196/207 duration at .050 0.467/0.479 lift on a 116 Lobe center
So which 5.3L do you have? As there different cams depending on year application.
Most 5.3L cams were 191/196 duration at .467/.469 lift on a 114. Now some were better. Like the L33 were the same or better than the LQ9.
I would just find another cam not worth the trouble to swap.
Old 07-09-2012, 09:32 PM
bww3588's Avatar
Ls6 cam. /thread
Quick Reply: 6.0 cam in 5.3
