Visual difference between Ls1/Ls2
LS1Tech Premium Sponsor
Like they said, knock sensors on side of block instead of under valley cover, cam position sensor will be in front cover instead of behind intake manifold at top of block, and if you can see that far (no front drive accessories) they are also cast with "6.0L" on the LS2's.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I was going to mention the same thing.
