Help need info on what mods to do.
Old 04-02-2004, 04:36 PM
vandal0-0's Avatar
Default Help need info on what mods to do.
I have a 2000 Z28 m6 with 150 wet kit,centerforce clutch, TR6 plugs,lid k&n filter,msd wires,smooth below,et drag radials&short shifter.I have $2000 to spend and I need some suggestions on how to get in the 10s if possible.I was thinking of Patriot heads & cam combo but I wanted to know what you guys thought would be best.thanks for any suggestions.
Old 04-02-2004, 05:09 PM
PunkNPonys's Avatar
With some good long tubes and a good catback or even cutout with a decent cam, should put you in the 10s with the 150shot. Check out the FMS cams. They are making some awesome numbers. Goodluck
Old 04-02-2004, 06:14 PM
badboy4life's Avatar
First i would do all the suspention a 12bolt and some et drags out back. then heads and cam.
