budget head choice - cnc
LS1Tech Premium Sponsor
Give us a shout, we can set you up!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
When porting heads I personally don't think budget should come to mind. If you are going to do this, then do it properly. That being said, TSP has a full machining facility and has some nice looking port options for the price. If money is no issue then I would just send them to AI and say have fun.
Internet Mechanic
DIY Hand porting which is really clean up work is budget, CNC can be inexpensive but again its generally not viewed to be that way.
Some needs to pay for the equipment, overhead, materials, and the work that went in making the program.
An alternative is to seek out used heads there are CNC and if the situation is a good one you can scoop up some nice used castings for quarters on the dollar.
We offer both new castings ported, and we can port yours to save you some money!
__________________
We do not port the 806 perimeter bolt heads. The 241 casting is the "entry level" casting we will port.
__________________
Cheap porting basically stops you from having it really having them ported well later so you are wasting a set of castings.
Do it once do it right.
Equipment cost money to buy, money to maintain, money to operate, money to program, money for replacement tooling etc. If someplace is half the cost of another shouldn't it bet the question WHY? what corners are cut?
There are areas you can maybe cut some corners or buy "budget for now" heads is not a good place to do it though.
Options are the same, pricing is a bit less because we aren't paying for castings. Exact cost depends on which casting you want ported.
__________________
