double roller timing chain
Old 07-20-2012, 10:33 PM
chevybayboy's Avatar
Default double roller timing chain
Whats the point of a double roller? And when should I upgrade to 1??
Also how to I know if I need an oil pump and should I upgrade to high volume?
Old 07-21-2012, 05:47 AM
RezinTexas's Avatar
Regarding the double roller, here is some info from a reputable source (Joseph Potak's LS book):
LS2 timing chain is stronger than LS1
double rollers are about 50% stronger than single roller
the factors that impact the need for a double roller are: high rpm's, high valve spring loads, and agressive cam lobes.
A nice feature of any aftermarket chain kit is the ability to adjust the timing by re-adjusting the crank gear on the keyway.
I chose a new LS2 chain/gear for my build because I will not spin past 6k, my valve lift is .570, and my cam lobes are mild XE. Assuming my timing events check out ok, I wont need to upgrade to an adjustable setup.
Hope this helps.
Old 07-21-2012, 06:41 AM
Hope this helps.
It does thanks alot man
Old 07-21-2012, 06:44 AM
MonmouthCtyLS7's Avatar
Ported ls6 oil pump and a ls2 chain is all you need and I would change them with a cam swap.
Old 07-21-2012, 06:56 AM
Thats wat I was thinking since I have the motor all the way broke down
Old 07-21-2012, 08:02 AM
vettenuts's Avatar
Often overlooked but likely more important. The timing chain damper will help prevent chain wrap and breakage. These are hard to find though. Most important, harmonic damper (pulley) will also play a major role in timing chain life. Some aftermarket harmonic dampers have been linked to timing chain breakage.
Old 07-21-2012, 07:01 PM
Thats good to know as well
Quick Reply: double roller timing chain
