LS1 Airboat
Old 07-21-2012, 01:58 PM
408Dakota's Avatar
Default LS1 Airboat
Just thought I would share my LS1 airboat build incase anyone else is interested. The boat came with a GM crate 383 that almost lasted 15hrs. COD, rod through block.
On with the repower. Its a 2003 truck 5.3 that was purchased with factory wiring harness and ecm.
Next i removed the factory Wiring harness from engine to remove wiring that is not needed for my build. Here is a pick of the leftovers.
Finished wiring harness. Now with throttle cable TB and IAC and TPS. Removed DBW. Bought a 2003 Express Van ECM to operate the IAC.
I installed a new timing chain, oil pump, and Comp cam kit# K54-426-11.
When engine was complete, the belt drive was bolted up
The engine is now mounted on the boats engine stand. Now for the tuning and testing. I will get some more pics and possibly a video when it hits the water. I am thinking the LS will put out more power than the (400hp) 383cdi.
Old 07-21-2012, 05:15 PM
Bill00Formula's Avatar
can't see the pictures.
Old 07-21-2012, 08:24 PM
408Dakota's Avatar
hope pics work now. Some more to come this week. Big thanks to:
WWW.LT1SWAP.COM
Old 07-21-2012, 08:59 PM
408Dakota's Avatar
I hope the pics will work this time.
Old 07-21-2012, 10:09 PM
parks450's Avatar
I see them. Saaweeeet build man I love air boats, their a blast. Good luck with the build
Old 11-05-2012, 07:04 PM
408Dakota's Avatar
Its installed and running.
Old 11-06-2012, 01:49 AM
01ssreda4's Avatar
Cool project!!!
Old 11-06-2012, 03:19 AM
vettenuts's Avatar
You of course realize we will need video once this puppy is in the water
Quick Reply: LS1 Airboat
