best harmonic balancer?
Old 07-21-2012, 07:26 PM
LsxNotchy's Avatar
Default best harmonic balancer?
What is the best harmonic balancer for a high revving double roller chain lq4?
Old 07-21-2012, 08:33 PM
LsxNotchy's Avatar
nobody?
Old 07-21-2012, 08:59 PM
99Bluz28's Avatar
You'll most likely hear, ATI Super Damper, but I have no regrets going with a Fluidampr years ago.
Old 07-21-2012, 09:04 PM
JUSTINSWS6's Avatar
Ati is the best!
Old 07-21-2012, 11:04 PM
LsxNotchy's Avatar
thanks guys
Old 07-22-2012, 12:51 AM
wildcamaro's Avatar
Ati is the best...see them in almost every race engine...the best would be the chainless setup with an idler gear in place of the chain to keep time...jk that's expensive race spec stuff from mast for the Brazilian NASCAR series
Old 07-22-2012, 01:00 AM
sweet99ss's Avatar
Isn't ati and slp the same one?
Old 07-22-2012, 02:19 AM
soundengineer's Avatar
No... ATI and slp are not even remotely close to the same..
Slp is just a shitty pulley...
ATI is an SFI damper...and is used by most NHRA teams
Old 07-22-2012, 02:48 AM
sweet99ss's Avatar
I always heard good things about slp pulley's.. I bough one a couple months back actually... Should I not install it?
Old 07-22-2012, 05:37 AM
PREDATOR-Z's Avatar
I've used MARCH with good success on most my builds.
Old 07-22-2012, 07:20 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Fluidamper. Up to 6,500 RPM.
Old 07-22-2012, 07:33 AM
RADEoN's Avatar
My slp 25 percent ud pulley works just fine.
Old 07-22-2012, 09:55 AM
its not about a pulley being able to "work fine"
when you go to an underdrive pulley, you are putting a smaller pulley on the crank, and it allows more vibrations.
once you start spinning to higher rpm's, you need more vibration control, which you cant accomplish with a smaller pulley smaller pulley.
the ATI balancer is a dampener....you will see more power gains from proper balancing than you will from underdriving....to a point that most people will see more power from the ATI standard size dampener than they will from an underdrive pulley...
there's a reason the ATI pulley is $450 and the SLP is only $250
Old 07-22-2012, 10:05 AM
Paul Bell's Avatar
Hey Scott! Ya on tour?
Old 07-22-2012, 10:13 AM
yep... Out with Jennifer Lopez and Enrique Iglasias...
by the way....I went with the ATI 918852.....
Old 07-22-2012, 10:29 AM
Paul Bell's Avatar
Cool, nice shows. Are you out with Abe V Systems? I did a thing or two with Jlo here in NYC, once with P-Diddy.
Yeah, you can't go wrong with the ATI.
The Fluidampr is a very good unit-it's even sold over the counter at GMPP.
However, over like 6,500 RPM, the ATI will damp the crank harmonics better. Fluidampr will even tell you this and advise you to use a ATI for higher RPM applications. Very respectful of a company to tell you to use their competitors product.
Old 07-22-2012, 10:38 AM
Clair Global.. the sound company I work for.....
agreed.. fluidamper is a nice choice for lower rpm applications...
once you start spinning over 6500, or once you start making more than 800 flywheel horsepower....
either way, the ATI the best choice...
Old 07-22-2012, 10:54 AM
Paul Bell's Avatar
Oh yeah right. Lemme know when you're in NYC again.
Any pics of this ride of yours?
Old 07-22-2012, 11:55 AM
My Setup is Currently out of the car...
I'm going to be transplanting everything into a Lightweight Foxbody Mustang... O.o
but here is a picture of how it was before I pulled it out to prep for the Mustang.
Old 07-22-2012, 11:57 AM
My ATI Damper...
With Moroso Vacuum Pump mounted in AC location using a bracket from Bob Ette over at AEICNC.
Quick Reply: best harmonic balancer?
