Differnent cam while engine is apart???
Old 07-24-2012, 08:30 AM
jgillen91's Avatar
Default Differnent cam while engine is apart???
91 camaro th400 with brakea 4500 stall, 9"rear 4.11 with spool. 28x10.5s et drags, 3300 lbs
Best pass 1.49 60' 6.809 @3 101mph 1/8. 10.72@126 126.24mph
Lq4 block. 030"over, stock crank, racetec flqattops, milled, valve job, ported ls3 heads, prc .650 dual springs, 11.25:1 compression , 93 octane, victor jr intake port matched, 1" spacer, 850 proform carb.
Currently has a eps speced. 235*/251* .624/.631 110 lsa +4 advance Shift at 7200-7400 rpm
I am looking to improve 1/8 and 1/4 mile time. Dont really drive it on street much anymore. Dont want to spin it any higher than 7200rpm. Must work with my .650 springs. Hydraroller.
What do yall think?
Old 07-24-2012, 10:38 AM
mark21742's Avatar
Your cam you have actually sounds pretty good, don't think you want to go much bigger if you want to keep it under 7,000 rpms
