Trickflow 215's and MS3
Or you can save money and do this with no PTV worries if you don't have the MS3 already.. https://ls1tech.com/forums/parts-cla...cator-cam.html
LS1Tech Premium Sponsor
That will not clear! You will need less cam, or a different head with more valve drop!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
It is not going to clear with the heads being milled.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
We have numerous heads that will work. Our ported GM casting Stage 1 LS6, Stage 2.5 LS6, and Stage 2.5 5.3L heads all work when setup for that cam. Also we can setup the PRC 215's and 227's to clear. Of course the TrickFlow 215's will clear it if they have not been milled as well!
We offer all of the heads I've mentioned at competitive pricing and would be happy to help!
__________________
What was your minimum pistons to valve clearance?
__________________
It is very close when it comes to piston to valve clearance.
__________________
Do you have the 5.3 heads in stock currently? Last time I emailed you guys you didnt have any or know if ya was goning to get any. Id like to get the most compression/power from a set of heads without flycutting with the ms3. What head would I be lookin at there?
I do have a couple sets of the 5.3L heads setup for the MS3 in stock currently!
__________________
What makes you think that 5.3s have smaller chambers than TFS 215? Aren't the 215s 64cc??Not to mention the 5.3s can't hold a candle next to the 215s
