my 706 heads milled .035 ???
Old 07-25-2012, 06:40 PM
jaywill's Avatar
Default my 706 heads milled .035 ???
to get my 5.3 9.5cr to 10.1cr...what cam will make the best tq & hp and have good ptv clearance ?
Old 07-26-2012, 07:57 PM
chrisfrost's Avatar
Go to Wallace racing and plug in You're #'s into their compression ratio calc ,,,,,,bore 3.779" stroke 3.622" comb chamb volume 61cc # of cylinders 8 ,,,,,piston dish ,stock 5.3L pistons have a 9cc dish which goes into the calc as a positive # deck height ,,,,,,stock 5.3L pistons come out of the hole like .010"-.015" ,,,,,,You'll need to know exactly ,,,,,,,,,,,,then if the calc gives You 9.5/1 ,,,,,,,then chnge the combustion chamber volume with all the other #'s the same try 59cc and see ,,,,,then 57cc until You get to 10.1/1 . Lets say it's 57cc that gets You to where You want to be ,,,,,,then come back to LS1 tech and do a search for how much milling needed to lower comb chamber vol by 4cc on 706 heads .
Old 07-26-2012, 07:59 PM
chrisfrost's Avatar
As far as cam goes ,,,,,,,,pay patrick g. $25 and he'll custom spec a cam for You're application and it will be the best cam to squeeze out the most from You're engine .
Old 07-26-2012, 08:56 PM
jaywill's Avatar
Thanks
Quick Reply: my 706 heads milled .035 ???
