How to find out what cam I have in my car
Old 07-26-2012, 12:29 AM
lq96.0's Avatar
Default How to find out what cam I have in my car
I bought a 01 z28 from someone and he said he put a cam in it put couldn't remember which cam it is
Old 07-26-2012, 12:52 AM
Storm Trooper's Avatar
I am not aware of any way to check specs on the cam... the only way would be for the guy to remember what cam he put in... to my knowledge there is not a camshaft spec finding machine! lol
Old 07-26-2012, 07:20 AM
Ethan[ws6]'s Avatar
When you degree a camshaft, you will know the duration and lift. You'll have to get a degree wheel and a dial indicator that will fit the lifter bore. I've never done it on and LS engine, but I have on an older 350. I imagine it would be a pain in the *** with the engine in the car. But you can figure out every spec this way.
Old 07-26-2012, 11:34 AM
redtan's Avatar
Sure there is, plenty of shops that can doctor a cam and get you the specs on it.
Although you have to remove the camshaft from the engine and send it off to someone who can do that.
Old 07-26-2012, 12:39 PM
wildcamaro's Avatar
If you pull the timing cover and the cam retaining plate usually most manufacturers etch which cam it is on the end of it
Old 07-26-2012, 01:03 PM
ss454327's Avatar
It's actually on the other end of the cam in my car. When I put in a new rear main I saw the cam specs were exactly what I was told they were. Either way it's not easy to find out...you couldn't call the person you bought the car from and find out?
Old 07-26-2012, 05:40 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I think this would be tough to do short of pulling the cam out and trying to find a serial number to reference it with. We get all of our cams from comp cams and they have a serial number ground into the back of the cam that we can reference with them to get cam specs. You could also take it out and get it cam doctored if you can find someone that does that.
Old 07-26-2012, 06:25 PM
farmington's Avatar
you might take a valve cover off and stick an indicator on #1 intake and #1 exhaust and see what lift you get. maybe you can find a cam that's close. Best you can do without taking the cam out and that's not worth the trouble.
Quick Reply: How to find out what cam I have in my car
