4.8 installing a ls6 CAM push rod question
Old 07-26-2012, 11:27 AM
groundczero's Avatar
Default 4.8 installing a ls6 CAM push rod question
I have an 02 4.8 and I am throwing a 02 ls6 cam in it.
I got new springs, but some people said I need a different length pushrod?
Is this true, or can the stock 4.8's work?
Old 07-26-2012, 12:40 PM
wildcamaro's Avatar
Do a search...
Old 07-26-2012, 03:39 PM
PREDATOR-Z's Avatar
You probably will need longer pushrods like 7.425 but you'll need to measure to verify that.
Old 10-28-2013, 02:44 PM
ridegreen78's Avatar
Did you ever get it figured out? I'm looking to do the same swap
Old 10-28-2013, 03:08 PM
Burken01's Avatar
Measure, it takes a few minutes.. Then you can decide on how much preload you want...
Plus you can learn a little about your engine, no guessing!
Old 10-28-2013, 09:43 PM
Y87bird00's Avatar
Measure. I put that cam in a 5.3, with .03 milled heads and needed a 7.35 pushrod. Get the $20 checker from summit or jegs ect
Old 02-01-2023, 11:02 AM
Natichevy's Avatar
Talking 4.8 lr4. Big cam pushrod size don’t know
I have a 2000 Chevy Silverado 1500 extended cab it has the GEN 3 4.8 5.3 lr4 with 862 heads it’s a 4.8 it has a 4L 60 E transmission rear wheel drive automatic I snapped my piston rod and half so I started rebuilding it I purchased a Elgin stage 3 sloppy cam kit Valve kit i’m pretty sure I’m gonna need upgraded push rods and I also need advice on a torque converter
Old 02-01-2023, 11:27 AM
Received 3,017 Likes on 2,348 Posts
It would be better if you started your own thread.
The following users liked this post:
LS1Formulation (02-01-2023)
Quick Reply: 4.8 installing a ls6 CAM push rod question
