PRC Dual Spring Seals
Hey guys I've read some people have problems with the seals so i want to get them on right. I have tapped the seal down the stem and it doesnt want to go farther bu it looks like there is a tiny gap between the bottom of the seal and the metal seat. Is this okay or does the seal need to be flush against the bottom of the separate seat?
thanks, so do the sockets really cause that much warping as an install tool for the seals if you dont just slam them? or should i be getting the specific valve seal tool?
the GM installer tool is a little Cup shaped piece.. .you only push them down by hand with their tool... and the seals do not touch the bottom
Kent moore makes this one in this thread.
https://ls1tech.com/forums/10654150-post11.html
