would you run this cam bearing or replace it
Old 07-27-2012, 04:07 PM
Turd Gen Guy
1nasty86's Avatar
Default would you run this cam bearing or replace it
doesnt have any marks on it or groves in it and just the one bearing looks like this.. cam that came out looks in perfect condition. motor is not going in a daily driver and may get 2-3k miles per year
Old 07-27-2012, 04:17 PM
3rdCoastPowerSports's Avatar
from your description of your use of the motor I would run it. You could change it since its the first one but I don't know if that is ok to just change one cam bearing. I have always changed all 5 at the same time. I would think as long as you measure then you would be fine just changing one bearing. Maybe someone who is for sure will chime in
Old 07-27-2012, 04:44 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Stock bearings will usually look like that when doing a cam swap, I wouldn't hesitate to run it as long as there is no scoring.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 07-27-2012, 05:43 PM
Turd Gen Guy
1nasty86's Avatar
Cool... Thanks you two!
Old 07-27-2012, 06:46 PM
Grimes's Avatar
run it.
