Ls1 vs ls6 heads
Old 07-28-2012, 05:50 PM
chevybayboy's Avatar
Question Ls1 vs ls6 heads
How much more do the ls6 heads flow over Ls1... I put my ls6 head next to my Ls1 and it seems intake and exaust holes are the same size?? So whats the diff.??
Old 07-28-2012, 05:56 PM
sjsingle1's Avatar
many many differences..........the LS6 exhaust ports are D shaped for 1............
Old 07-28-2012, 06:01 PM
FASTFATBOY's Avatar
LOL, about 40 hp.
Old 07-28-2012, 06:19 PM
Really 40 HP? Ok... Well looks like ill be porting my ls6 heads while there off
Old 07-28-2012, 06:30 PM
FASTFATBOY's Avatar
Ls1 makes about 300 to the wheels
Ls6 about 360 to the wheels.
Heads are at least 35hp of that number.
Old 07-28-2012, 06:35 PM
Felix C's Avatar
Originally Posted by FASTFATBOY
LOL, about 40 hp.
BS & more BS.
Correct answer: 10% more flow per every chart I have seen here.
Old 07-28-2012, 06:49 PM
Originally Posted by Felix C
BS & more BS.
10% how many more pony power would that be over stock
The following users liked this post:
Will Thompson (02-27-2021)
Old 07-28-2012, 07:45 PM
FASTFATBOY's Avatar
BS & more BS.
Ok, so where does the power difference come from LS1 vs LS6?
My stock LS6 makes 385 to the wheels with mild bolt ons and exhaust through a six speed.
Both stick cars:
LS1 300 to the wheels
LS6 355 or so to the wheels
55RWhp difference, which is about 80 at the flywheel.
Auto car:
https://ls1tech.com/forums/dynamomet...only-dyno.html
Pat G says about 25rwhp, about 35 ish at the flywheel.
https://ls1tech.com/forums/dynamomet...-increase.html
If you take the time to do a GOOD valvejob and mill the heads to get 11 to 1 compression even more power is there.
Old 07-28-2012, 07:48 PM
Felix C's Avatar
Question was about flow nos. Nothing more. Actual answer in terms of gain on a stock LS1 is 15rwhp.
Whatever personal experience you provided is from an LS6 engine. Entire package.
Old 07-28-2012, 07:59 PM
FASTFATBOY's Avatar
Your the man, carry on.
Old 07-28-2012, 08:04 PM
Felix C's Avatar
Cold hard facts. That is all.
Old 07-28-2012, 08:06 PM
Thanks both you guys for info all I can get helps
Old 07-28-2012, 08:19 PM
So will,porting and polishing my heads change my compression? If so lower or higher
Old 07-28-2012, 08:33 PM
Theblacknightls1's Avatar
Ls1 heads 230 cfm ls6 260 cfm. Correct me if I'm wrong.
Old 07-28-2012, 08:35 PM
No. Porting will increase flow. Milling the heads will increase compression.
Old 07-28-2012, 08:41 PM
Ok cool thanks
Old 07-28-2012, 08:49 PM
Mike Morris's Avatar
Some good info here to read...
http://www.c5registry.com/documents/ls6/page2.htm
Old 07-28-2012, 09:22 PM
Originally Posted by Mike Morris
That was def. A nice piece of info
Old 07-28-2012, 09:45 PM
crainholio's Avatar
Any metal you remove from the combustion chambers will lower the compression ratio. Easy to get it back with milling, though.
Be aware it's very easy to create imbalances in airflow if you get crazy with the hand-porting. I only recommend polishing to remove the casting roughness in the ports for non-professionals (like myself). And flush 'n brush them thoroughly afterward to get all the abrasives and aluminum dust completely gone.
Leave the carbide burr to the pros who know what they're doing and can get all 16 ports to reasonably symmetrical volumes and airflows.
Old 07-28-2012, 09:50 PM
Keith_Shapiro's Avatar
I'll tell you soon I just took my 806 heads off today and the 243's gone in this week
Quick Reply: Ls1 vs ls6 heads
