Need some info on this cam...
Old 07-29-2012, 12:23 AM
BLK95-Z's Avatar
Default Need some info on this cam...
I did some trading a while back and ended up getting this cam thrown in with some other parts. The guy said he was running it in a 408 with TFS 235's.
Specs are: 247/260 @ .050 .647"/.647" 112+3
Can I run this in a 370? Im collecting parts for a carbed drag project and had this laying around...
Thanks
Old 07-29-2012, 12:57 AM
sepsis's Avatar
That's a huge cam. It would make it's best power at over 4k RPMs.
You would definitely need to fly cut the pistons, upgrade the valve springs and more.
I'm not an expert though.
Old 07-29-2012, 12:40 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Well if you are building a drag 370 it might not be bad depending on your head selection. Ideally for drag carb setups the LSA would be closer to a 108-110. If its something you have laying around and want to try I don't see a problem with it, just keep in mind it is pretty large. Probably wouldn't drive so well on the street. I don't think clearance would be an issue in a built motor because of valve reliefs. Always worth it to check though.
Old 07-29-2012, 08:00 PM
BLK95-Z's Avatar
Thanks. I do just have it laying around and thought about using it...all I really have at the moment is a block/crank/cam. Would some stock 799/243's work or would I need something bigger? Im sure its way to big for ls3 heads
Old 07-29-2012, 09:48 PM
Fbodyjunkie06's Avatar
I think it would work fairly well in a 370. It should also like nitrous if you ever planned to spray on it with the early EVO that cam would have.
If your building a 370 with aftermarket rods/pistons then you wouldn't have any clearance issues because the measurements for the valve reliefs will be taken with the cam you have in mind from the start. This means you could have the cc piston that would make the most out of the compression you could run depending on the fuel type you plan on using while not having clearance issues with a set of stock chamber heads.
Just something to think about, and I think it would work well with either type of head you plan on running.
Old 07-29-2012, 10:16 PM
BLK95-Z's Avatar
Awesome. I didnt know if it would be stupid to build a motor around a cam I had laying around but if it works for what Im trying to do then I will. I did plan on spraying it later on.
I dont really have a goal, just a stripped roller and some parts and would like to go racing. Thanks for the info
Old 07-29-2012, 10:19 PM
In a drag application I would probably lean towards LS3 heads out of the couple you stated. With the right aftermarket pistons you can fit those heads on there no problem. I would expect it make decent power for the application.
Old 07-30-2012, 10:31 AM
I also would go with a set of LS3 heads and use the piston to achieve the compression you want.
I honestly think that cam will surprise you in the amount of power it will make.
