Replace Oil Pressure sender without removing intake?
Old 04-04-2004, 12:32 AM
abarus's Avatar
Default Replace Oil Pressure sender without removing intake?
Is there a way to replace the oil pressure sender without removing the intake. First time I swapped to 1s6 intake I had a vaccum leak, pulled and reinstalled it. Works great, except now the oil pressure sender is broken... My hands need a break.
Any ideas?
Will pulling the valve cover work? or anything similar.
Thanks,
Old 04-04-2004, 12:58 AM
383ss's Avatar
really doubt it. don't quite see the big deal. removing the intake is pretty easy, especially if you know how to do it
Old 04-04-2004, 10:49 AM
Zero2Sixty's Avatar
Like 383 said, I just dont see how you could being that its too damn tight to work back there with the intake in place.
Old 04-04-2004, 11:08 AM
PongoX11's Avatar
Yeah I am thinking not. Congradualations you are to become the intake swapping master!
Old 04-04-2004, 01:35 PM
2001-WS6's Avatar
There simply is not enough room to get at the sender without removing the intake. You'll run the risk of snapping it off in the hole with angles that would be required to get at it even if you used your local six year old neighborhood kid with small hands to reach back there.
Rick
Old 04-04-2004, 02:14 PM
felton316's Avatar
You can put the sender in there with the intake still on. I do it all the time. I pull the sensor before taking the intake off, and put it on after I install the intake, this way there is no chance of breaking the sensor. All I use is a 3/8" ratchet, 3" extension, and the oil pressure sensor socket. The only tricky part is finding the hole with out seeing it, but you'll get use to it.
Old 04-04-2004, 02:16 PM
EVIL's Avatar
drop the motor out of the car....
Old 04-04-2004, 02:57 PM
abarus's Avatar
Thanks for the reply guys... I'll try Felton316's method before pulling it again... Should be able to pick up the sending unit from GM on Thrusday.
Thanks again,
