PO704 code with hard starting. Help!
Old 07-29-2012, 05:31 PM
95mysticta's Avatar
Default PO704 code with hard starting. Help!
Well just did the ls1 PCM conversion to my lt1. Everything's been running great then got a code po704 low input clutch switch. Cleared the code and came back. Starting was normal for the first couple starts but now I'm having a hard time getting it going. I'm assuming it's an out of adjustment clutch switch or it's bad. Anybody ever throw this code and have hard starting issues afterwards. What was the end fix?
Thanks,
Matt
Old 07-29-2012, 09:15 PM
95mysticta's Avatar
Anybody? Need to get this issue solved ASAP!
Quick Reply: PO704 code with hard starting. Help!
