LQ4 advice.....
Old 07-29-2012, 05:42 PM
Skippy1's Avatar
I picked up an LQ4 My plans are to put it into and S10 I am going to run the LS6 intake manifold with the LS6 injectors and fuel rails along with the LS6 cam and valve springs.
I want to deck my heads as much as possible to bring up my compression. I have the ability to deck my own heads I just need to know how much I can take off without getting valve to piston contact.
Thanks guys if anyone has this info let me know
Ryan
These plans are not set in stone and if you guys recommend a different set up please speak up. Heads seem to be out of my price range right now but I am not against pulling the motor down and putting in a set of LQ9 pistons.
Old 07-29-2012, 06:23 PM
bww3588's Avatar
Your going to run out of head to cut before you run into ptv issues.
However, I suggest claying it then milling accordingly.
Old 07-29-2012, 06:37 PM
1BadBlkB1tch's Avatar
honestly bro u can buy stock ls3/l92 heads for like 7-800$ complete and if its that bad go on summit and buy 1 head at a time you will be better off in the long run trust me ls3/l92 heads on a lq4/lq9 run pretty mean and flow great
Old 07-29-2012, 06:50 PM
Skippy1's Avatar
What will I gain out of going to an ls3 head over just decking mine.
just flow characteristics???
Old 07-29-2012, 07:07 PM
Bo185's Avatar
Why not just find a set of used 243. You can reuse your LS6 intake and not have to buy a new intake with the LS3/L92's even though the LS3's do flow really well stock but figure the cost of intake and new 90mm TB as well. The smaller chambers will boost CR more. You can mill them as well to gain more CR as well should get around 10.4 with a 243 head depending on HG of course with the LQ4 piston, more CR if milled. Be cheaper than installing flattops.
Old 07-29-2012, 07:09 PM
ok if your heads are 317's or 873's your flow chart looks horrible and restricted you would need to mill,deck,port n polish and 3 angle to even think you can break 300cfm's
avg intake CFM = 178 and at 600 lift CFM = 240
avg exhaust CFM =138 and at 600 lift CFM = 177
the specs for the stock Ls3/l92 heads are as follows
avg intake CFM = 250 and at 650 lift CFM = 327 goes .50 lift higher then lq4 heads
avg exhaust CFM = 179 and at 650 lift CFM = 240
so you can see why the LS3/L92 heads are so much better they flow over 300 CFMs at .450lift which your going to have way better top end and proally an increase of 25-40 whp over the heads you plan on doing ls3's react real good with a fast ls3 intake and big cam with the ls3 heads you should expect 400hp+ with a good cam and tune
figuring hes on a budget i can see the 243's as i hav some laying around but it sounded as he hasnt bought any manifolds or anything yet just wanted to give him a power upgrade choice with the 243's and ls6 ull be ok but best bang for your buck is ls3 heads,mani,and i got a TB if u need one lol 90mm :-)
Old 07-29-2012, 07:13 PM
Skippy1's Avatar
Thanks guys where would i find some L92 or LS3 heads for that kind of price??? I cant find them that cheap anywhere
Old 07-29-2012, 07:15 PM
im runnin a lq4/lq9 408 stroker and im going to be putting on TEA Stage 2 Ls3/l92's with a fast 102 and a 102 TB 100mm tsp maf and just about every bolt on known to man and im shooting for 600+ Rwhp at titan on motor
Skippy1's Avatar
I am on a budget and havent bought anything yet. What did the 243 heads come on???
hold on ill get you the links
Old 07-29-2012, 07:17 PM
Skippy1's Avatar
Are you selling off your old setup???? any parts you have that you want to sell that could help me out I would be interested in
Old 07-29-2012, 07:18 PM
http://www.ebay.com/itm/GM-Performan...7daa70&vxp=mtr
thats each head like i said my buddys runnin a lq4 stock 364ci with these stock heads on a ms3 high rise carbed intake and some other goodies on a regal and went 10.40's down OSW ill find his yoube video for you
to be honest im a stand up guy and theres not much good left off my old setup as look at my build thread youll see what im talkin about tho i have some 205 heads brand new just got outta machine shop hella work done but i know outta your price range.... the 243's i have need to go be recon'd and need valvetrain
http://www.ebay.com/itm/NEW-High-Per...29593c&vxp=mtr
another guy and he even put on the bottom on a lq4 budget build made 503hp untouched
Old 07-29-2012, 07:23 PM
Skippy1's Avatar
I appreciate that and for that price i will go that route hands down. With those heads what cam and intake manifold should i run???
Old 07-29-2012, 07:27 PM
ls6 motors or camaro ss 2002's i believe or 02 ws6 trans am someone correct me if im wrong? but i do have a 90mm throttle body i can sell you if noone buys it with my manifold tb combo deal
well figuring untouched they can handle a .550 lift cam so to be 100% honest id order the cam from TSP as theyve helped me out alot i would think you want to stick with a
ls3 cam or ive run a torquer v2 i might still have it id have to check i got 2 or 3 cams where i build my cars or u can upgrade the springs and run any cam you want really but best thing to do is call TSP or contact one of them on here and ask them whats the best cam setup for lq4 with ls3 heads and theyll def help u sorry i cant help out much more then that i just know what runs great together i personally love ms3's powerwise and soundwise there mean and fun to play with
http://compare.ebay.com/like/2906833...Types&var=sbar
budget wise u can run a stock ls3 mani but make sure when u buy a mani its for a ls3/l92 as its rec ports not cathedral
Old 07-29-2012, 07:36 PM
adamantium's Avatar
243s never came on any 98-02 camaro or firebird. They came in z06s, ls2 gto's and a few other random trucks and SUV's. 799 cast i read is the same thing as far as port design.
Old 07-29-2012, 07:39 PM
ok was unsure thats why i put that i new theyre ls6 heads but thanks for that info :-)
Old 07-29-2012, 07:44 PM
adamantium's Avatar
No prob. The 01-02 LS1 cars came with 241s! Easily mistakable with 243!
Old 07-29-2012, 07:46 PM
yea thats true i have a bad set of 241's with a hole in the passenger side and they look identical to the 243's i have
Old 07-29-2012, 07:47 PM
Skippy1's Avatar
would you run stock ls3 injectors with that set up or step up to something bigger???
would my stock truck throttle body bolt on to the ls3 manifold enough to get it running and swapped into the truck that would be easy enough to swap out while the motor is in the truck
Old 07-29-2012, 07:58 PM
as far as i know you would need a 90mm throttle body pm me im pretty sure the one i got laying around will work
pm JustinCody hes running a lq4/ls3 setup at the moment im sure he can help you out with what cam and all the other stuff to make it run great
Quick Reply: LQ4 advice.....
