connecting Rod bolts
Old 08-01-2012, 05:41 PM
chevybayboy's Avatar
Question connecting Rod bolts
Ok ive been searching all day reading alt of diff forums and now im alittle confused
im wondering when are stronger connecting rod bolts needed?? Current mods
K&n ram air
Ported polish tb
Bbk intake
243 heads harpland sharp 1.7 rockers
Torquer v2 cam
Bbk lt into x pipe out (true duals)
future mods
75 shot of nitrous
So 2 questions am i going to need to rod bolt the highest i plan on taking it is 6500 rpm
And can i change them with motor still in car or do i HAVE to drop the engine out?? Im still using stock pistons stock rods?? Any input help im about to start my build journal and need to get everything i need thanks everyone
Old 08-01-2012, 05:47 PM
KILLER-LS1's Avatar
You probably won't need them with that small of a nitrous shot. The bolts do help with higher rpms though, and if you're driving the crapmout of it, and spraying it all the time, then it might be more worthwhile.
You can do it with the motor still in the car, you just need to drop the oil pan, which is still a pretty big project
Old 08-01-2012, 05:53 PM
Ok.cool i think ill get the Katechs so i dnt have to get it resized im dont think im going to be spraying all the time i prob put 4 k miles on the car if that a year.. But thanks man for the quick responce i think all my research for evrrything i need is done now... Time to get to work
Old 08-01-2012, 05:56 PM
Sales1@Texas-speed's Avatar
Not a bad idea to replace them with the Katech bolts, but definitely not a requirement for your doing at this point.
