Comp cams rocker arm trunnion bolt torque
Old 08-01-2012, 08:57 PM
boostedrides's Avatar
Default Comp cams rocker arm trunnion bolt torque
I need the speck for this quick help please. Thanks ls1tech
Old 08-01-2012, 09:05 PM
_GTO_'s Avatar
22 ft./lb just like the stocks .
Old 08-01-2012, 09:53 PM
cool thanks. I just got her done.
Old 08-01-2012, 11:04 PM
96s-10ss's Avatar
I dont trust the 22ft lbs spec. I know its straight from GM but its non adjustable and I ALWAYS go 35 ft lbs. If it wont strip/damage the threads why not. Also I always turn the motor to no load, then torque them, then repeat twice. the bolt always torques down more the second pass!
Old 08-02-2012, 08:42 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I've found 22lb ft to be insufficient and I've had to reinstall and re-torque many customers rocker arm that ended up loosening on the dyno due to that exact specification. I believe the GM service manual spec is actually 24lb ft, but I've found that 26lb ft to be more on the safe side. I've never had a rocker arm loosen up at 26lb feet. That is what I use on the trunnion kit bolts on several engines a week with no issues.
Remember to seal your intake rocker bolts with good quality RTV sealant if your heads are ported. The threads alone will not seal and engine oil will be drawn into the intake port from the rocker arm area.
Old 08-02-2012, 09:17 AM
Good info! I guess I'll have to go back and seal the intake bolts then. I have prc 2.5 5.3L heads.
Old 08-02-2012, 10:04 AM
-Joseph-'s Avatar
Sweet, I like the ported 5.3L heads. If there is oil on the intake bolt threads, use some carb or brake cleaner on the bolts and bolt hole threads then air or used compressed air to dry.
Quick Reply: Comp cams rocker arm trunnion bolt torque
