is 25-30 oil pressure too low??
i was driving my boyfriends car and when it was ideling, it was between 25-30 psi and when i was going about 60 mph, it was a little lower than 40 or at 40...
he has a ported ls6 oil pump and a new shortblock that is suppose to run high oil press also... could the o-ring on the pump fell of a little??
just mainly, can it hurt anything?? thanks
Sounds like the oil pump could be failing. I have the same problem with my car. I was convinced it spun a bearing. However, at start up the oil pressure at idle is good, and it drops off pretty quickly.
Right now, I'm debating putting my new heads, cam, timing chain, and oil pump in. I have valvetrain noise. Perhaps my motor is not ruined, but my oil pump is failing...obviously much worse then your new one.
I would definitely keep an eye on that oil pressure. And use your ears as much as your eyes.
https://ls1tech.com/forums/generation-iii-internal-engine/157141-could-another-spun-bearing.html
That seems a little low to me. I can't say I remember the exact number, but I think my car is at around 60 psi on a cold start up and then backs down to a little over 40 once she is warmed up. This is at idle. I don't know, 25-30 psi just seems a little low.
last car i built was a 2000 Z28 and it only had about 25-30 psi at idle and at WOT it MIGHT have gotten to 50. car now has 15000 miles on it like that and pulls hard, runs hard. with no spun bearing
mike
mike
My motor has about 30#'s or so at idle, and in the 40#'s while cruising and about 58# at WOT. It has about 8,000 miles on the re-built motor with a LS6 pump in it. Funny thing is that it had 45+#'s at idle when it was first re-build, but it has slowly dropped down to the new #'s. Seems to run fine and no weird noises.
The "O" ring can NOT fall as you describe it. The flange on the input port neck prevents that from happening, but it could get damaged during installation. 25 or 30 lb of pressure might be enough, but if you were running 40 at idle earlier on, but now your pressure has dropped for some reason that is something to be concerned with and begs closer inspection. Your oil pressure doesn't wake up one day and decide to drop by 20lb. That just doesn't happen. It might not be something critical, but if it is you need to fix it soon. It could be the sender or the gauge. Those won't cause engine damage, but worn bearings that allow pressure to bleed off or a pump that has reduced efficiency for some reason can cause catastrophic engine failure. Don't let that happen to you.
LS1Tech Sponsor
I worked on a car recently that had oil pressure at 35psi,hot at idle.This was a built shortblock.When doing a cam change I noticed the front cam bearing moved back away from the oiling hole.Replaced the bearing with the Cam and now oil pressure is 60psi at idle.Car never really made noise just lower than normal oil pressure.Figured ignitial startup spun the bearing out of place.
