Are 241 heads adjustable or nonAdjustable valves?
When it comes to doing valve jobs 1975 is easier and faster than 2005. Having to measure each valve and cut it the the correct thousands takes time unlike with adjustable valves where you just cut the seat and the valve and throw it back together.
Ethan [ws6], you sir seem to be a bitch. I'm sure I've did a many more valve jobs than you. And in fact there is talk about sbc engines. On this same post actually.
Moderator
Well it sounds like you suck at doing them. If you're not precise and consistent with the valvejobs, you can end up the chamber volumes measuring all over the place. It doesn't matter if it's s stud mount or pedestal type, you would want to be consistent with your valve drop.
Lol what. You are the one that brought up SBC. OP specifically asked about 241 heads. Also, he's talking about valve adjustment. Not doing a ******* valve job. Even if you have done more valve jobs than I, which I doubt, your knowledge seems limited. No need for you to get butt hurt.
That is a very scary comment, please share with us where you work so we can all avoid such a shop like the plague.
A friend built a gen 1 and checked PTV at the 4 corners and it was fine, only later did he find out that the valve job depth varies .038 and several valves did hiton the inner cylinders.
Far as asking about the 241 heads specifically how about the gen 3+ motors are nonadjustable.
This should be a strong lesson to everyone else about who you trust to do work for you.
