Head Gasket for 853 heads?
Is it absolutely necessary to use graphite head gaskets when installing 853 heads??
Or can you get away with MLS head gaskets?
Yes I know the 853 heads have a notch cast into them thus reducing the surface area for the head gasket to seal to. And that this is the commonly held reason for using the graphite gaskets with the 853 heads. I'm just wondering if this is actually a valid reason for using them as opposed to MLS gaskets.
Mine had the notches & you can see where the gasket has a spot for it on #3 & #5 cyl.
Kinna like the old wifes tale about the ARP rod bolts....
