What is a good step up from a 224/230 cam?
Old 08-08-2012, 03:37 PM
fatboyq's Avatar
Default What is a good step up from a 224/230 cam?
Ive been rocking the LG G5 cam now for 2 years in my 04 GTO M6. Nothing really wrong with it, just want to see if I can move on to something "better". it is a 224/230 .581 .57x 112 If I remember correctly. My car is not a track car, mostly street car.
I want lots of low-mid range power and still have a good pull to redline. I have 243 heads, LT headers,. I put down 394/394 uncorrected with this cam on a stock maf, paper factory filter/stock box, no udp. I want to be around 430rwhp or so, no particular reason for that number..
What cam would be worthwhile to switch to? I like this cam just wish it had more pin u back power, it drives like stock, well almost stock, which is good..
Old 08-08-2012, 05:56 PM
99Bluz28's Avatar
If you want lots of low to midrange power I would go with a tighter lsa(109-111) and around a 227-231 duration on the intake lobes and around a 230-234 on the exhaust lobes.
So what's the ICL (intake centerline) of you current cam?
You could go bigger, but you'll be giving up lowend power for sure!
Old 08-08-2012, 06:09 PM
99Bluz28's Avatar
The G5 (224/230) is only listed as on a 114lsa.
If you have the Cam card find out what the ICL is.
Old 08-08-2012, 06:45 PM
Turd Gen Guy
1nasty86's Avatar
231/239 .617/.624 lsl cam would do the damn thing! And drive great with the proper tune
Old 08-08-2012, 06:59 PM
brian 05 gto's Avatar
would cam would be good for a ls2 with stock stall and its a auto
3rdCoastPowerSports's Avatar
seems like it would get up and move in the higher rpm range but that cam has 11* of overlap, might kill your bottom end. still should scream like a banshee over 3k
Old 08-08-2012, 07:03 PM
A buddy of mine has a 06 gto ls2 he got a cam in his and ported tb and intake with stock valve springs and everything he makes like 415 at the wheels on a 218 duration with .546 lift 113.5 lsa and plus 4 degees advance.He was telling me if i got a ls2 cam i could send it off where he did his and have it grind to his specs and i could keep my stocks stuff but since my car has 69,000 miles im worried about that any advice would help
Old 08-08-2012, 08:26 PM
99Bluz28's Avatar
brian 05 gto, quit jacking the thread!
FYI, it's not hard to start you own thread.
Thanks!
Old 08-08-2012, 10:22 PM
garygnu's Avatar
maybe port your heads and get a fast intake.
Old 08-08-2012, 10:40 PM
01ssreda4's Avatar
I don't think going up in cam size and maintaining low end are an option. You have to be willing to give somewhere.
Old 08-08-2012, 10:51 PM
streetlegalls1's Avatar
Default cam
That is a good cam,Keep the cam and consider moving on to a better set of heads where you will get the gains i think you are expecting
Old 08-09-2012, 08:50 AM
thunderstruck507's Avatar
Leave it alone. A cam big enough to gain you some power will cost you low end.
You will end up spending a decent chunk of money on something that will help marginally at best.
Old 08-09-2012, 08:55 AM
Turd Gen Guy
1nasty86's Avatar
Set of T.E.A. or A.I. ported 243's would be a good next investment
Old 08-09-2012, 09:16 AM
gMAG's Avatar
If you can spare the money, send your heads out to be worked.
It's the most direct way to achieve the power you want.
Old 08-09-2012, 09:52 AM
Fbodyjunkie06's Avatar
GTO's are heavy, as others have said I wouldn't recommend going to a bigger cam as you want to retain a good amount of average power in a set-up like this.
Again as others have said going up in cam size will net maybe 10-15rwhp if that even and you'd be giving up average power to do so.
Old 08-09-2012, 10:06 AM
fatboyq's Avatar
Thanks for the advise, I think it might be prudent to look else where for more power, just wanted to see if a cam swap might get me 25hp over the current cam. i will get that UD pulley, LS2 maf, and a legit catback and see if that gets me more snap when i hit the gas. Maybe a fast intake down the road.
Old 08-09-2012, 10:38 AM
mark21742's Avatar
Don't waste your money on a MAF...either keep your stock maf or delete it and go SD tune. I think the only way you will get what you want is to do a head end intake swap...like said above, a bigger gem will give you dome more HP, but make it less streetable and drop low end power
Quick Reply: What is a good step up from a 224/230 cam?
