Stage 2 head, how much can they be milled?
Old 04-05-2004, 01:39 AM
slxrti's Avatar
Default Stage 2 head, how much can they be milled?
I have a pair of stage 2 heads, to be used with a 579/555 114 cam.
how much can I mill the heads, and run 92 gas.
slxtri
Old 04-05-2004, 02:22 AM
blk~2000~Z28's Avatar
Are those 5.3, 5.7, or LS6 heads? If they have not been milled already then they can be milled quite abit assuming there will be no P/V problems with that cam.
Old 04-05-2004, 10:10 AM
slxrti's Avatar
they are 5.7 heads, can I mill .030 w/o pv issues?
slxrti
Old 04-05-2004, 12:46 PM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
It's a hard call to make because there is a LOT more that goes into p-to-v clearance than the max lift of the camshaft. What is the duration? Duration is equally important, as is the aggressiveness of the ramp profile. If it's large duration with a very aggressive ramp profile, then it could certainly cause clearance issues. The only true way of knowing is measuring with a dial indicator. This is how we check p-to-v clearance on all of our setups.
Feel free to call or e-mail me if you have any other questions. I'm here to help.
Trevor
Texas Speed & Performance
__________________
