Do i need a new timing chain??
Old 08-11-2012, 10:13 PM
El_TransAm98's Avatar
Default Do i need a new timing chain??
i was gonna swap my cam saw the timing chain to loose..do you think i need to upgrade??
http://youtu.be/kmIhl2TSPTs
Old 08-11-2012, 10:34 PM
01_SuperSlow's Avatar
It does look a little looser than the one in the SS i had.
All stock chains have some slack though.
If it has high miles just get it replaced, you're just an oil pump removal away now.
Btw, I replaced mine with a C5R chain which had just a little slack.
Old 08-11-2012, 10:40 PM
thanks ..i saw it loose ive seen loose chains but not bad like this was i got a ls2 chain right now ill just upgrade for that for now ..
Old 08-12-2012, 07:47 AM
mjs1012's Avatar
Well if you're in there swapping the cam what's another $40 and half an hour of your time for a little peace of mind.
Old 08-12-2012, 01:18 PM
Black 99 Bird's Avatar
Yep the LS2 will do you fine.
Old 08-12-2012, 05:58 PM
Thanks for the info
