Should I consider new valve springs?
I have about 45,000 miles on Comp 918 springs and I'm wondering if I should replace them. Cam is a TR224. I've never had an issue with them. I don't like fixing things that aren't broke but I don't like replacing engines either.
LS1Tech Premium Sponsor
Definitely pull a few and get them checked!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Well if I pull a few to check I may as well go ahead and pull them all and replace them.
Ryne, why do you like the PSI beehive over the 918's? What other springs would you consider? I feel like Comp quality control has been falling off a bit in recent years. I'd be interested to hear your opinion too Matt.
We like the PAC beehives. The 1218's would do great for that one, and they work with your existing hardware!
__________________
Ive heard too many stories about the PACs, especially here lately on the boards. I used the beehive 918s with that exact same cam in my first LS1 for many miles. I would definitely replace them for sure. You'll be fine with another set of 918s, they dont have the problems in these new era 918s as the other ones did a few years back.
Yes, same seats, seals, locks, retainers as your 918's use!
__________________
Please consider my .660" Lift Dual Polished Platinum springs with tool steel retainers for $219 shipped. Thanks
https://ls1tech.com/forums/new-produ...its-219-a.html
I just had a friend do the same thing on my Dad's 99. Had about 35K on 918's and replaced them with PAC 1218's. He didn't pressure test the old ones, as was pointless at that point, but he did say they had a slight sag of maybe 80-90 thousandths. I also had the plugs swapped right away while in there and taking the old ones out. Haven't driven yet, prob no noticeable differerence, just peace of mind.
Not to highjack the thread but i have the comp 918s aswell and probably have around 20k miles on them with the crane 1.82 rockers and a stock cam, would it be advised to change them aswell?
Installed the 918's. That took much longer than expected. All the retainers were stuck and centering the new springs was a pain. I ender up using the trick flow spring compressor and I had to drill out the holes to accomodate the studs. Here's the valvetrain all buttoned up. All is well.
