Post your Heads/Cam setup + hp/tq #'s
Old 10-28-2012, 01:37 PM
  #41
john563's Avatar
TSP stage 2.5 5.3 heads
fast 90/90
232/238 6xx 6xx 111+2lsa(xfi lobes)
hooker 1 7/8 lt
dynomouth
435 rwhp 407rwt through a 5c 4400 stall and 3:73 gears
i have since swapt to a 4inch mufflex y(better merge) and 4inch dynomax bullit dumped
so i would imagine with a better merge i should have acouple more ponies(i hope lol)
Old 10-28-2012, 02:54 PM
  #42
HCI2000SS's Avatar
405 rwhp & 370 rwtq with mods in sig. Although i'm thinking this was a very stingy dyno lol
  #43
Sales@Tick's Avatar
-346 C.I. 100k mile short block
-Stock 241 heads
-Ported Fast 92/96mm TB
-Custom 239/247 .624"/.624" 110+0 camshaft on LSL lobes
-ARH 1x7/8" headers with 8" extensions off the collectors to Vibrant 3"x5" mufflers
-4" intake tubing to TB with bell mouth in front bumper connecting piping to TB
TH400 with custom 9" FTI stall(4500 on motor)
12 bolt w/ spool and 4.11's
The graph I am going to provide were done on a Dyno Jet 224xlc with 19psi of air in the 275/60 Hoosier Drag Radials.
Note the average power this cam has in the power band it's being used in...
Added this cam trapped 129mph on several occasions with the old 5900 stall and would go 105 in the 1/8th. With the nitrous stall and 10* of timing pulled and a rich *** AFR it went 99mph in the 1/8th on accident as the window switch didn't turn the nitrous relay on due to pushing a wrong button on it while changing activation RPM. I would think with full timing and proper AFR it'd go 105-106mph on motor, but the E.T. wouldn't be near as good as the old 5900 stall.
This is in my camaro that weighs 2780 empty 3010 with me in it.
  #44
MikeWS6's Avatar
What type of dyno?
Old 10-28-2012, 02:58 PM
  #45
HCI2000SS's Avatar
Originally Posted by MikeWS6
What type of dyno?
It was a Dynojet dyno. Funny thing is that the owner/operator said that almost all HCI LS1's make anywhere from 390-420 rwhp on his dyno. So with that in mind i'm right in the ballpark I guess lol. I was under the impression this combo would be good for like 420-440 rwhp
Old 10-28-2012, 04:52 PM
  #46
dgcustomz's Avatar
I helped a buddy build an engine for his 00' Camaro Z28. Here are some specs:
LS6 short block
Flycut the pistons
Comp Custom grind 238/244 586/596 114lsa
cometic .040 head gaskets
Lingenfleter stg3. 317 heads that we had milled .060",
Professional products 96mm intake and
fast 92mm tb
asp underdrive pulley
1-3/4 pacesetter headers
3" true duals through raceline bullets
stock maf
blackwing air lid
k&n air filter
ford redtop injectors
racetronix pump and hot-wire kit
Stage 2 Tdp t56
4.10 gears
26" m/t et drags
Car was pulled up to 6300 rpm's and made 464 rwhp. After that power seemed to start dropping and we figured out it had some valve float. We swapped to a 7.350 pushrod and got 472rwhp. But, we also swapped to a 85mm slp maf.
We switched over to a 28" tall tire and lost 15rwhp.
We will be putting the intake and tb combo up for sale and switching to a victor jr single plane and 4150 tb. We'll see how it does.
Old 10-28-2012, 05:24 PM
  #47
MonmouthCtyLS7's Avatar
Hand ported 243's, G5x2 Cam, Mac Mids, 85mm Typhoon Intake...404 Rwhp uncorrected..Not to shabby for a stalled auto and hand worked heads.
Old 10-28-2012, 06:33 PM
  #48
kirbyman03's Avatar
Patriot Predator heads 205 runners, milled to 61cc, EPS cam 230/234- 600/612 on 113+2 rest of mods in sig 436rwhp 390rwtq with 91 octane tune only 21* timing
Old 10-28-2012, 06:58 PM
  #49
firebird99's Avatar
401 with mac mid's and a typhoon not bad all but why not take the motor to 6500 because it looks like it was still climbing or did you get valve float?
Old 10-28-2012, 08:18 PM
  #50
404 and my buddy that built the motor asked the same thing. The guy I went to for the dyno tune is a Stang guy and he didn't want to push it on a stock bttm end...he laid down a good tune and its his equip who am I to argue.
Old 10-28-2012, 08:53 PM
  #51
A.R. Shale Targa's Avatar
23,000 mile LS6 original short block. MLS .053" head gaskets. EPS 218/226
DIY(cartridge rolled bowls) 241s flowed 246/200..GM valvejob..LS6 valves..
Lunati Gold Duals..7.400 P-rods..Heads milled .030"..XS Power long tubes w/
3" cats and X-pipe..Corsa axle-back..K&N filter in factory air box, stock MAF
and TB....375/355 SAE through M6
Old 10-28-2012, 10:40 PM
  #52
KingPin1094's Avatar
I haven't built mine yet, but heres the plan:
TEA/TFS 215cc heads
EPS custom grind to match the heads
FAST 92/92
Fast toys 98mm lid
SSRA CAI
1 7/8" headers
3" duals
Looking to get about 450rwhp with the manual trans
Old 10-29-2012, 02:37 AM
  #53
MikeWS6's Avatar
Yeah dynos are crazy as you can see how much the numbers vary vs the track times.
Old 10-29-2012, 03:56 AM
  #54
Trunion King
bene's Avatar
Stock LS1 bottom end with:
SW long tube headers- bassani true duals
MTI lid- ported MAF- PP TB- LS6 intake- 28 lbs inj- Powerbond pulley
EPS 222/226 113 LSA- stock GM 243 heads- supporting valvetrain mods
Best numbers it put out were 440-443 RWHP however it did put down 488 rwhp but I think he ran the car on the wrong gear? Dyno was a dyno dynamics machine.
Either way, I'm going to re-dyno my car again when I get back in the states with a mustang dyno or a dyno jet as this guy's tune was a hack. PE and VE tables were jacked so I retuned it with my HPTuners.
Old 10-29-2012, 08:48 AM
  #55
FRiCK's Avatar
C5 Z06
Stock short block
Livernois stage 3 243's 59-60cc
230/230 111+2
1 3/4" LT, 3" X, Ti's
Vararam w/ duct
21*
462/434 dyno dynamics
Track time in sig
PTV was.............. tight. Very tight.
Old 10-29-2012, 09:53 PM
  #56
The Scammer Hammer
dr_whigham's Avatar
^^ That looks like a fruggin explosive combo! ^^
Old 03-16-2013, 12:26 PM
  #57
MikeWS6's Avatar
I just got mine back today.
414/383 Mustang dyno
Old 03-16-2013, 12:36 PM
  #58
Hand ported 243's, G5x2 Cam, Mac Mids & Cats 404 Rwhp through a loose 3600 stall
Old 03-23-2013, 12:59 PM
  #59
MikeWS6's Avatar
Originally Posted by LS1T56FTW
http://www.youtube.com/watch?v=78SPJCWmHZ8
The car has some other supporting mods that I guess are worth mentioning, it has a monster clutch with the 18lb flywheel, it has an ASP UD crank pulley, ported MAF, etc.
So thats about 550 at the crank? damn
Old 05-25-2013, 08:18 PM
  #60
MikeWS6's Avatar
Bump for more setups
Quick Reply: Post your Heads/Cam setup + hp/tq #'s
