wont idle for sh##t
wont idle for sh##t
ok guys help me out here, just had a 224/224 installed and now there having trouble with the m.a.p. there getting a P107 CODE, engine check light will come on and run and idle sh##TY and then run fine and then again sh##TY. WTF.!! my car is a 2002 t.a.whats the chances that the m.a.p. is bad or is this cam the culprit. please give me some segestions. help.!!
Under criminal investigation for fraud
With the 224/224 cam your car should idle like a dream. If your map sensor is truely bad you could be experiencing these problems. It's just not common for a '02 car to have a bad map sensor. Bring it to us and we will fix it for you. If it doesn't require anything major, I won't charge you. How's that sounds?
